Results 1 to 10 of 19
Thread: New Headset
    G3FAHR's Avatar
    Rep Points: 9685
    06:46 PM
    QLD, Austtalia
    New Headset
    Looking to buy a new headset for my Xbox one. The old one needs to be replaced as it worked great for my Xbox 360 but I can't control the volume on the Xbox one. It is a turtle beach x-7, I believe as I am too lazy to check. Any suggestions on what I should get in replacement?
    Experience: 1,545,814
    iiTz_XenRail's Avatar
    Rep Points: 2350
    12:46 AM
    United Kingdom
    Bravo Co 1st Platoon
    Do you have a spending limit on the headset?
    If you don't I would suggest getting a pair of Astros or if you have spending limit either turtle beach again or tritons
    Experience: 480,450
    G3FAHR's Avatar
    Rep Points: 9685
    06:46 PM
    QLD, Austtalia
    No real spending limit.
    G3FAHR's Avatar
    Rep Points: 9685
    06:46 PM
    QLD, Austtalia
    Quote Originally Posted by Xaliance View Post
    Which Astros do you recommend?
    Rep Points: 2350
    12:46 AM
    United Kingdom
    I have A50's and they are wireless unless you want to keep them plugged in while you play.
    A40's are wired and just as good
    Experience: 480,450
    G3FAHR's Avatar
    Rep Points: 9685
    06:46 PM
    QLD, Austtalia
    Any problems with the a50s? My other turtle beach wireless kept disconnecting from the Bluetooth. Had that problem with two different sets.
    Rep Points: 2350
    12:46 AM
    United Kingdom
    No it has a small hub that's connected to the console. Optical cable and usb power cable. You will just have to buy a 10ft or however long cable you want to go from headset to console if it's about to die so you can still play.
    You can charge your headset through your pic ports as well if you aren't playing
    Experience: 480,450
    G3FAHR's Avatar
    Rep Points: 9685
    06:46 PM
    QLD, Austtalia
    How about the Bluetooth connection. Does it drop out?
    Rep Points: 2350
    12:46 AM
    United Kingdom
    No I haven't had any problems with it and I've had it a year and a half
    Experience: 480,450
    G3FAHR's Avatar
    Rep Points: 9685
    06:46 PM
    QLD, Austtalia
    You have me sold. Off to take a look on Monday. Fingers crossed that they are not over $400 here down under.
  11. The Following User Says Fucking Hell Yeah ! to G3FAHR For This Fucking Post:
    Batman_OnA_Stick (April 16th, 2016)
