If you can't log into the site don't worry and follow these instructions.
[ol]
[li]If you used to log in using CAG your username, remove the CAG from your username.[/li]
[li]If you still can not log in after removing the CAG from your username, recover your password by Clicking here.[/li]
[li]If still can not log in after recovering your password send me an email at CheechDogg@cagclan.com[/li]
[/ol]
This was done to have the correct gamertags for everyone on the roster so that there is no confusion as what is everyone's real gamertag. Unless your XBL Gamertag or your PSN ID has CAG as part of it, you must leave the CAG out in order to log in.
Your original passwords were not changed therefore you should be able to log in with your original passwords. Again, if you used to log in using CAG followed by your username remove it and you will be able to log in.
