When is your 2 weeks up?
Don't get discouraged as this is typically a minor problem where sometime it will flip recruits (pink name) to registered user (white name).
It's easily rectified on the back end by Cheech or Randuken but the reason I'm asking when your recruitment period is up is when you get processed your name will move signify that you are a member and the registered user status will disappear.If you ain't got long on your recruitment it may be worth while to wait rather than have Cheech or Randy flip you to pink then again once your awards are recommended.
It's fine asking........
Bertus went off topic,you asked about your status and he went elsewhere with the convo.
Your leadership within your assigned Company should be keeping up to date with your recruitment period and therefore recommending your awards for Cheech or Randuken to process(Randuken has stated quite a few times that he normally only does this on the weekend).
CAG CheechDogg (November 14th, 2016)
Man....... I check everything that I possibly can on these forums including this post of yours in the MIA thread -
Just a headsupp, I'm taking a MIA from the forums, because I didn't feel confortable the way how it now goes, because I have been very busy, and only the last 2 weeks 1 was once on the forum. ofcourse I;m checking it on my phone, maybe some posting. but for now I just need to make everything in my favor. I'm not sure when I'm will be back, but probaly after the launch of IW, and , So If someone will take overmy duty off for the Bravo Awards Request, it wouldd help a lot,
You where absent because you didn't feel comfortable about how things where then so it's quite obvious that you are going to miss things and then you seem shocked when someone leaves?Don't get that at all......
