Results 1 to 10 of 15
Thread: NAT Type Issues Solved
Discuss the Rainbow 6 Franchise here
    Chet Norris's Avatar
    Rep Points: 14499
    February 27th, 2025
    08:55 PM
    Southern Indiana
    I was having trouble connecting to a party with Gemini he gave me some tips to try which got me in the party. I still have a "Moderate" NAT type which could cause other connection problems. Here is what I got from Ubisoft support
    If you are receiving connection issues, start by testing your Xbox Live connection via the Network Test Utility on the console.
    1. Start at the Xbox One main menu.
    2. Press the Menu Button.
    3. Select Settings.
    4. Select Network Settings.
    5. Select Test Network Connection.
    6. Select Test Multiplayer Connection.
    Note: If you receive any errors in steps 5 and 6, please follow the on-screen prompts to resolve the issues presented.
    7. Select Detailed Network Statistics if you are experiencing lag in gameplay. If your Upspeed/Downspeed are consistently not what your Internet package includes, you may need to contact your ISP.
    There are three possible NAT types:
    - Open NAT (Green) has no restrictions and will be able to connect with any other players.
    - Moderate NAT (Orange) will have some restrictions and will be unable to communicate or play with users with a strict NAT.
    - Strict NAT (Red) may not be able to join or communicate in certain game sessions. Average matchmaking wait times will be affected.
    If your NAT type is moderate or strict, please try the steps below:
    1. Restart your network hardware. Turn off your Xbox One, modem and router and wait 15 - 30 seconds.
    2. Fully power up your modem.
    3. Fully power up your router.
    4. Turn on your Xbox One and test the Xbox Live connection again.
    If you still have trouble then you may have a firewall interfering with your connection. Please configure the following network ports and enable UPnP through your router.
    Xbox Live Required Ports
    UDP: 53, 88, 500, 3074, 3544, 4500
    TCP: 53, 80, 3074
    Rainbow Six: Siege Required Ports
    UDP 3074, 6150
    TCP 80, 443
    Directions for configuring network ports are specific to the software and hardware being used, and can be found by visiting the manufacturer's website. Websites such as http://www.portforward.com offer tutorials on how to open ports on your router.
    If the issue persists, please try clearing your system cache. To clear the cache on your Xbox One, you will need to power cycle the system. Power cycling will reset the network card and clear the cache.
    1. On the console, press and hold the Xbox button for about 5 seconds until the light behind it turns off. This will power off the console.
    2. After the console has shut down, unplug the power cord and wait 2 full minutes.
    3. Plug the console back in and turn it on using the Xbox button.
    If this does not solve your problem, try placing your Xbox One in the DMZ of the router or establishing a direct connection to your modem and retry.
    If you continue to experience issues please submit a ticket here
    Experience: 853,002
    Rep Points: 14499
    February 27th, 2025
    08:55 PM
    Southern Indiana
    If you play Tom Clancy's Rainbow Six Siege, you may want to think about setting up a port forward for it to improve your online gaming experience. There are many advantages to setting up a port forward for Tom Clancy's Rainbow Six Siege, for instance:
    · Less lag
    · Improved connection
    · Fewer crashes when online
    · Easier to play with friends
    · Better quality voice chat
    · Enhanced overall online experience
    On this page we have links to guides for Xbox One and Playstation 4 specific to Tom Clancy's Rainbow Six Siege. Want to learn how to forward your port? Follow one of the sections below to see easy-to-follow instructions and get it done today.
    http://portforward.com/networking/static-ip-xbox-one/
    Experience: 853,002
    February 27th, 2025
    05:55 PM
    You to power cycle both your modem and router for the moderate or strict NAT to go away ..
    1. Disconnect power source from all your devices this includes all laptops, modems and routers
    2. Turn on modem first
    3. Turn on router only after all lights on your modem are lit
    4. Turn on your xbox one first then anything else
    The reason this happens is that sometimes your laptop or desktop's firewalls throw up a security call and prevents you from getting an OPEN NAT TYPE ....simple
    Experience: 289,145,493
    Rep Points: 14499
    February 27th, 2025
    08:55 PM
    Southern Indiana
    Finnaly got open NAT. Had to make a change in my cable modem.
    Sent from my SM-N920P using Tapatalk
    Just Win Baby!
    Experience: 853,002
    Gemini328's Avatar
    Rep Points: 69921
    February 27th, 2025
    09:55 PM
    Quote Originally Posted by Chet Norris View Post
    Sweet note we can party up easier and get that marksman knocked out
    Experience: 8,474,923
  6. The Following User Says Fucking Hell Yeah ! to Gemini328 For This Fucking Post:
    Chet Norris (January 11th, 2016)
    February 27th, 2025
    05:55 PM
    That's because your old ip address was blocked for something. ..since its a static adress it would need to get released then get a new one assigned to it
    Sent from my SM-N920V using Tapatalk
  8. The Following 2 Users Said Fucking Hell Yeah ! to CAG CheechDogg For This Fucking Post:
    CAG JB (January 12th, 2016),Chet Norris (January 12th, 2016)
  9. #7
    Rep Points: 14499
    February 27th, 2025
    08:55 PM
    Southern Indiana
    I was so pumped to have my NAT type Open. I'm connecting to Multiplayer quickly. But for some reason I could not connect to Terrorist Hunt games. and I could not Party up with Elias last night. Hard to say if I'm having a issue or it's game related?
    Anyone? Cheech?
    Just Win Baby!
    Experience: 853,002
  10. #8
    February 28th, 2025
    02:55 AM
    Anyone? Cheech?
    Check your ports are configured,if you visit Ubisoft they have all the correct ports on there.Nearly certain that Gemini posted the correct port info on here also.
    I was running into the same issues and I just cut to the chase and changed my port settings through my router manager and haven't had a problem since.
    Things like connecting to a party wouldn't be to do with Ubisoft but your individual ISP or at a long shot xbox live itself
    Experience: 52,082,963
    February 27th, 2025
    08:55 PM
    Quote Originally Posted by CAG Gemini328 View Post
    Finally connected with Chet good games waiting for his post to confirm games CAG material go Chet!
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Experience: 12,524,856
  12. The Following User Says Fucking Hell Yeah ! to StormySGT ELIAS For This Fucking Post:
    CAG JB (January 14th, 2016)
  13. #10
    February 28th, 2025
    02:55 AM
    Quote Originally Posted by StormySGT ELIAS View Post
    Good shit man,your time zones close to Chet isn't it?
