Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 36
Thread: Spring Patch Incoming!
    dreag2121's Avatar
    Rep Points: 57983
    February 5th, 2025
    06:59 PM
    Delaware
    Full notes.
    http://www.dsogaming.com/news/battle...now-available/
    Battlefield 4 – Spring Update Changelog:
    STABILITY
    – Fixed multi platform crash related to audio
    – Fixed several multi platform server crashes
    – Fixed Server crash that would happen in some cases when players were switching teams
    – Fixed an issue where users were left in an Infinite loading screen when attempting to connect to a server
    – Fixed a multi platform single player crash
    – Fixed a bug which caused 2% of joins into an empty game server to fail
    – PC: Several client and server crash fixes
    – PC: Fix for a crash that occurs when exiting the game client (AMD cards)
    – PS4: Fixed a common crash on PS4
    GENERAL IMPROVEMENTS
    – Fixed a situation where the player has an auto-throw gadget equipped in the LEFT gadget slot and use it while holding the sidearm, the gadget will stay in the players hands.
    – Fixed an issue where the player would sometimes get stuck in the kill cam if receiving damaged from multiple enemies
    – Terrain and model destruction now sync better with explosion effects
    – Added advanced gameplay options to toggle Parachute Auto deploy, Auto Peek Over and Auto Side Lean
    – Small vehicles now can get unstuck by melee just like the boats and jet skis
    – Several Netcode improvements (see detailed description above)
    – Passive spotting distance reduced from 1200m to 100m * Spotting cone angle reduced from 3 degrees anywhere to starting at 3 degrees and narrowing down to 0.15 degrees at 1200m
    – Currently highlighted objective retained when commo-rose gets active so it is easier to select Attack/Defend for it
    – Fixed an issue where the stairs would disappear if players were revived on them. This would happen on multiple levels.
    – Fix an issue where claymore kills were not being counted for recon for stats
    – Fixed an issue where if the user plays a couple of MP Hardcore rounds prior to entering the
    Campaign, the single player campaign would not regain health after being hit
    – PC: Removed the friendly fire lock on the preset for CLASSIC
    – Fixed an issue where the user receives an inaccurate killcard when killed by a remote-controlled vehicle (e.g. EOD bot, Mortar)
    – PC: Added functionality for users to move both the CPU/GPU overlay graph and the network performance graph
    – Fixed an issue were the kill assist dog tag shows the wrong kill number in “My soldier”
    – Console: Fixed a bug where a player will remain stuck in the main menu indefinitely if the controller they are using is assigned to anything other than Controller 1
    – Fixed an issue with mastery dog tags showing up twice once they’re unlocked
    – Several fixes for exploits on multiple levels
    – Squad Obliteration: Fixed issue where a bomb that was forced reset could be “re-dropped” resulting in multiple bombs showing up.
    – Squad Obliteration: Disabled round time extension. Now the round time will pause whenever a bomb is planted if time has expired instead of extending only if the score is tied or if the losing team plants a bomb if they are down a point.
    AUDIO
    – Unique sound for headshots added
    – Bullet impact sounds on soldiers improved (using a silencer helps a lot here)
    – So called “Random callouts” improved for own team
    – Optimized the Lumphini Garden levolution mudslide sounds
    – Destruction sound added for WeatherStation buildings on Arctic
    ART
    – Fixed an issue where some camos would not display properly in 1st person
    – Fixed a graphical issue with the sheets/flags etc. affected by wind which were moving a bit too much
    USER INTERFACE
    – We’ve added stats to 49 existing dog tags including many favorites from BF3. Show off your skills!
    – Fixed an issue where the player shoots an enemy with a vehicle weapon, the hit indicator was displayed again when exiting the vehicle
    – Enabled network performance overlay on XBOX One. It can be enabled/disabled in the menu options.
    – Moved the 3 new playlists added in the Winter Patch to the top of the list and added highlighted them in yellow
    – Fixed the levels in the server browser filter list to be sorted in order per release
    – Improved HUD clarity for red dot sights based on CTE feedback.
    – Fixed duplicate Dog tag names that were present in some languages
    – Tweaked and updated the “Help me” icons (need ammo, need health etc) – icon now shows only if you can actually help.
    – Fixed an issue where the user was unable to see changes from HUD option screen for “Soldier Optics Reticle”, Helicopter and Jet Pilot Hud” and “Vehicle Driver and Vehicle Gunner Hud”
    – Increased size of jet ALT, Speed and PMS displays
    – Fixed an issue where the Misc HUD transparency advanced gameplay option would affect the customization screen weapon/gadget info element
    – Removed ‘ID_M_SERVERTYPE_RANKED’ from the left bottom corner of the loading screen in multiplayer
    – Removed incorrect burst UI indication for CBJ PDW as the weapon does not support burst fire
    – Fixed an issue where Soldier camo would be reset after each round transition
    – Added squad obliteration to the squad join settings
    – Fixed an issue where a damage indicator appears over the initial cut scene when starting a new Campaign
    VEHICLES
    – Masters of all jets get special Battlefield themed contrails when wearing any of the jet master dog tags or the Jet Fighter medal dog tag
    – Fixed an issue where the grey vision present when a user is at low health is also present after the user exits a vehicle in which he regains his health.
    – Fixed an issue where the user is unable to kill an enemy that is located inside a Jeep or a Stationary Weapon with the defibrillator
    – Fixed an issue with the options where turning ON the “Decouple aiming from turning” the “Vehicle aim relative control” has no functionality
    WEAPONS
    – Added 5 new weapons
    – Adjusted the ADS scaling and FOV controls to make the optics not magnify more than their default
    – “Headglitch” fix: Weapon down state using cover peek system in combination with the proper bullet spawn positions (from weapon instead of eye)
    – Updated night vision optics (see above for details)
    – Fixed an issue with the ACOG scope where its leftmost bar stretched to a solid black block when aiming down sights.
    – Fixed the tactical light on the MTAR-21
    – Fixed an issue on some sniper rifles where the range finder used in combination with the flash hider would cause issues with the range finder functionality
    – Fixed issues with the Belt Feeder/Autoloader not functioning on certain weapons.
    – Full weapons balance pass and suppression mechanic update (see above for details)
    – Sniper weapon tracer/Impact improvement to make it visible for longer distances
    – Fixed an issue with the M16A4 where the laser sight accessories would appear when ADS with FLIR/IRNV
    – Fixed bug with flashbang that was preventing it from reaching intended brightness and duration.
    – Fixed the UI for weapons and accessories to reflect correct values in the customize screen
    – Updated all weapon tracers to make them more clear and visible
    – Added overheating message to some stationary weapons that were previously missing those messages
    GAME MODE
    – Added Gun Master game mode to the 10 base game maps
    BATTLELOG
    – Implemented and adapted Battlelog for Battlefield 4 Spring Patch
    – Additional underlying preparations for deprecation of need to install Battlelog web plugin
    – Minor improvements to new Chat system
    – Fixed Premium calendar progress indicator to show correct progress
    MAPS
    SIEGE OF SHANGHAI
    – Added cover areas on Siege of Shanghai for Squad Obliteration
    – Fixed an issue where the user could see out of game world through a building wall
    – Moved attack helicopter that was stuck inside wall on Siege of Shanghai
    ROGUE TRANSMISSION
    – Fixed an issue where the destroyed dish parts would cause occlusion issues.
    – Grenade launchers now properly explode on the Concrete around the Research Facility
    OPERATION METRO 2014
    – Adjusted the TDM/SQDM/DOM, addressing issues with teams spawning too close together at the start of a match.
    GULF OF OMAN 2014
    OPERATION LOCKER
    – Fixed collision issues
    – X360: Optimized memory to reduce crashes
    HAINAN RESORT
    GOLMUD RAILWAY
    – Fixed a stone fence near the north edge of the map that was misaligned with the ground, making it appearing like it was floating.
    TEST RANGE
    – Added hit indicators to the targets
    – Various smaller bug fixes
    I'm happy about the test range.
    --- Excuses are not reasons...excuses are a way not to take fault. Reasons are what happened despite your efforts.---
    Experience: 2,411,725
  2. The Following 2 Users Said Fucking Hell Yeah ! to dreag2121 For This Fucking Post:
    BlameItOnGod13 (May 27th, 2015),CAG CheechDogg (May 27th, 2015)
    February 5th, 2025
    11:59 PM
    Out of it all id say im most happy about the fix to the head gliching.
    Now all these head glitchers are going to have to use their own thought process and develop skill to succeed instead of using a well known glitch.
    Experience: 51,817,389
  4. The Following User Says Fucking Hell Yeah ! to CAG JB For This Fucking Post:
  5. #13
    Villian's Avatar
    Rep Points: 7379
    February 5th, 2025
    02:59 PM
    england
    I've just redownloaded bf4, hmu if any of yous fancy a game. Be warned tho, I'm as newby as you can get to the bf series(played like 3 games 2 months ago)
    Experience: 1,730,404
  6. The Following 3 Users Said Fucking Hell Yeah ! to Villian For This Fucking Post:
    BlameItOnGod13 (May 27th, 2015),CAG CheechDogg (May 27th, 2015),dreag2121 (May 27th, 2015)
  7. #14
    February 5th, 2025
    11:59 PM
    Quote Originally Posted by CAG Villian View Post
    Be more than happy to play man and tbh weather u have dlc or not im quite happy playing basic vanilla maps.
  8. The Following User Says Fucking Hell Yeah ! to CAG JB For This Fucking Post:
  9. #15
    February 5th, 2025
    02:59 PM
    Nice ... I might just re-install BF4 although I am really happy playing Hardline right now ...
    Experience: 288,290,781
  10. The Following 2 Users Said Fucking Hell Yeah ! to CAG CheechDogg For This Fucking Post:
    BlameItOnGod13 (May 27th, 2015),CAG JB (May 27th, 2015)
  11. #16
    February 5th, 2025
    06:59 PM
    I can't fucking hell no this on my phone and I just spammed fucking hell ya right away... God damnit.
    I was messing around with the AN94 last night and it's definitely not what it was on bf3 and if your not getting dome pieces then yah the damage isn't great. I can say it's much faster on burst then it is on auto for some odd reason.
    Gonna try the grozas out tonight as well as the L86. One of the grozas is pretty whack, don't remember if it was the PDW or the carbine. I really wish they brought the IAR back for Support, that was the best ranged LMG but I guess the L86 will have to do.
    Hopefully this spurs some life within Whiskey.
    Experience: 48,859,798
  12. The Following 2 Users Said Fucking Hell Yeah ! to BlameItOnGod13 For This Fucking Post:
    CAG JB (May 27th, 2015),dreag2121 (May 27th, 2015)
  13. #17
    Villian's Avatar
    Rep Points: 7379
    February 5th, 2025
    02:59 PM
    england
    Quote Originally Posted by Johnbai84 View Post
    Yh man, ill add u in mo, just let me know when ur on
    I've only got the 10 hour trial for hardline, n I've used 5 on single player, saving the rest for next time ur on lol
  14. The Following User Says Fucking Hell Yeah ! to Villian For This Fucking Post:
  15. #18
    February 5th, 2025
    11:59 PM
    As far as I know the Pdw grozas comes with the silencer and the carbine doesn't.Had maybe 2 games with the carbine and it seems not to harsh.First impression it seemed to have a decent fire rate so seems like its capable of keeping up with most carbines.Not to sure about the limit to attachments though.
  16. The Following User Says Fucking Hell Yeah ! to CAG JB For This Fucking Post:
  17. #19
    February 5th, 2025
    11:59 PM
    I'm normally around from 8pm our time on Monday,Tues,wed though this weeks activity may be a bit random due to setting aside a bit more time for family and quality time but yeah that's my normal schedule.
    Mondays my real good night as I finish work Monday morning at 8am and that's me until I start shift at 1am Friday.
  18. The Following User Says Fucking Hell Yeah ! to CAG JB For This Fucking Post:
    Villian (May 27th, 2015)
  19. #20
    Villian's Avatar
    Rep Points: 7379
    February 5th, 2025
    02:59 PM
    england
    Copy that dude, I've already got you added so as you've probably noticed I'm pretty active so Amy times good for me
  20. The Following User Says Fucking Hell Yeah ! to Villian For This Fucking Post:
