Results 1 to 10 of 11
Thread: Need Some Help
    Gemini328's Avatar
    Rep Points: 69921
    April 22nd, 2025
    02:41 PM
    Need Some Help
    Alright fellas, I need some help. Not sure if you guys will know how to help or not. So recently my internet has been working fine until I turn on my xbox. The second I try to turn it on it kills my wifi. The router says that everything is fine, but it doesn't exist on any of my devices. Every so often it will successfully connect but after like 5-6 times of restarting my wifi.
    I have tried setting up my routers DMZ for the xbone but to no avail. I was wondering if you guys had any ideas? This is really starting to get on my nerves and need to try to get it fixed. anything will help. THanks
    -Gem
    Experience: 8,591,448
    April 22nd, 2025
    02:41 PM
    I don't know if port forwarding would help with this. You try googlin it?
    Experience: 49,694,657
    Gemini328's Avatar
    Rep Points: 69921
    April 22nd, 2025
    02:41 PM
    yeah that is where i got the DMZ host idea. granted i could have used the wrong ip address aswell. I guess i will try a different route tomorrow if i can find one.
    HG867's Avatar
    Rep Points: 40809
    April 22nd, 2025
    02:41 PM
    Kentucky
    Quote Originally Posted by Gemini328 View Post
    Reset factory defaults on your xbox?
    Experience: 6,168,988
  5. The Following User Says Fucking Hell Yeah ! to HG867 For This Fucking Post:
    CAG SILENT (April 16th, 2015)
    Gemini328's Avatar
    Rep Points: 69921
    April 22nd, 2025
    02:41 PM
    No haven't done that yet
    April 22nd, 2025
    10:41 AM
    This one is interesting ... I have no ideas here my Man ...
    Experience: 291,147,330
    SwampFox4388's Avatar
    Rep Points: 2850
    April 22nd, 2025
    02:41 PM
    South Carolina
    My guess would be reset factory defaults but i know that can be a pain. I had the kind of the same issues and a was lucky enough to be able to reset everything router included and it decided to work right. Good luck and keep everyone posted so if it happens to anyone else the answer will be out there.
    KCCO!
    CAG Dogg Level: 26 [?]
    Experience: 106,051
    Next Level: 125,609
  9. The Following User Says Fucking Hell Yeah ! to SwampFox4388 For This Fucking Post:
    Tricky3 (April 18th, 2015)
  10. #8
    OnixEwok's Avatar
    Rep Points: 61213
    April 22nd, 2025
    01:41 PM
    Ontario, Canada
    Are you connecting wifi directly to the providers kodem or do you have your own wireless network hub?
    Experience: 8,166,704
    Anim II's Avatar
    Rep Points: 2245
    April 22nd, 2025
    12:41 PM
    Chicago
    I had the issue to where my xbox would keep disconnecting me out of nowhere. try setting up a static ip for just your xbox and see if that helps. because what might be happening is your router is trying to change the ip to the xbox at any time and it might cause the issue. if you have a static ip for your xbox then your modem/router wouldn't try to give it a new ip because it will just be one ip all the time.
    Experience: 283,937
  12. #10
    Gemini328's Avatar
    Rep Points: 69921
    April 22nd, 2025
    02:41 PM
    Sorry for the belated response guys. Thanks for the ideas. Going to try them out today since I finally have a day off after 2 straight weeks of non stop work
  13. The Following User Says Fucking Hell Yeah ! to Gemini328 For This Fucking Post:
    OnixEwok (April 21st, 2015)
