CAG COD 1st Brigade
Call of Duty WW2
CAG Clan Forums Check In CAG on Facebook CAG on Twitter CAG YouTube CAG RSS Feed
Results 11 to 19 of 19
Thread: COD: AW Sensitivity
Discuss the Advance Warfare Regiment of CAG's Call Of Duty Brigade here
    OnixEwok's Avatar
    Rep Points: 61213
    November 29th, 2024
    03:37 AM
    Ontario, Canada
    Quote Originally Posted by XxXN1TeSh4dEXxX View Post
    On the flip side your sensitivity setting in my opinion will usually reflect towards your play style I have personally noticed the higher setting is good for less running and more slow moving tactical or light camping gameplay and the lower setting I find better for a run and gun style. For example hard scoping with high sensitivity can be an asset where as quick scoping on a high sensitivity can be very hard . very easy to move past your projected firing point
    I actually ramped up my sensitivity because I found I was getting beat on corners and sudden gun fights because by the time I turned around I was dead. Mind you it took about 20-30 to tweak my muscle memory to control it and be successful with it.... Another thing that I find worked alongside side my sensitivity to better myaim and reaction was when I started using these bad boys...
    http://www.razerzone.com/ca-en/gamin...er-chimaera-51
    The 50mm driver with Neodymium magnets creates such a crisp 5.1 doubly surround sound that I can actually hear which way your coming behind me and turn towards you before you can react to my tur king around which often gets me the first shot,especially since my high sensitivity allows me to 180 quickly
    On a side note what are your thoughts on using stick attachments to improve grip and such... Do they work? Or would I be wasting my money.
    Experience: 7,855,336
    Azrael's Avatar
    Rep Points: 22204
    November 29th, 2024
    03:37 AM
    Manchester, IA
    I actually used to use a straight up pro controller was like 300 bucks and I miss it man... The higher thumb pads on the joy sticks and triggers sticking out farther was so much better than a standard controller
    Experience: 4,206,445
    xsilentgoodbyexx's Avatar
    Rep Points: 1455
    November 29th, 2024
    12:37 AM
    Yuba City, California
    I run a 7 sensitivity when I play normally, sometimes I jack it up to a 15 depending on what weapon I'm using. AR I'll use 7. SMG I'll use 15. Since when I use an SMG more than half the time I'm hip shotting cause I ran into someone.
    Experience: 215,525
  4. #14
    Azrael's Avatar
    Rep Points: 22204
    November 29th, 2024
    03:37 AM
    Manchester, IA
    OK so just an update on the sensitivity. While I was completing my marksman with HUXLEYS INC I turned my sensitivity down to both 13 and 8 in a couple of matches. It actually hurt my game play for one simple reason. When I move from one spot to the next I run and my high sensitivity is sliding me to constantly look side to side in no time at all where as when I turned it down I found my self walking or moving in short precise straight lines to stay under more cover because when an enemy would pop out I could not get that instant turn and for on them giving me a disadvantage. This is just my personal opinion and experience find your mid and ride it the whole way home. I know I'm staying at 18 and up lol
    Rep Points: 1455
    November 29th, 2024
    12:37 AM
    Quote Originally Posted by OnixEwok View Post
    If you're going to invest any money into something like that I would just save up to get a SCUF 4PS controller if you have PS, if you have Xbox I recommend Battle Beaver controllers. They allow you to press buttons (X,O, etc) without taking your thumb off the right analog stick so you can perform moves that weren't possible before. It takes some time to get used to, but once you do you'll notice a big difference, because that split second you take your thumb off that camera stick to press jump to perform and exo move someone could gun you down.
    Experience: 215,525
  6. #16
    November 29th, 2024
    12:37 AM
    I play with my sensitivity on 4 . For me it works out just fine .
    I'm a Run n Gunner at Heart .
    But I'm also a Part Of CHARLIE DELTA so I also hold a spot down and wait for them flying Idiots to Boost my way lol
    Experience: 31,680,580
    OnixEwok's Avatar
    Rep Points: 61213
    November 29th, 2024
    03:37 AM
    Ontario, Canada
    I am not quite sure where I stand yet on those controllers with the extra paddles... Nothing against those who use them but I find a personal battle versus how fair it is for me to just spend the cash so I can have an advantage. The game is originally design to be played with stock controllers.. So that's how for now at least I am going to perfect my game... If I was playing in more competitive circles where everyone is using them I may shift my mindset on paddles... What I was referring to is if it is worth adding grips as my thumb sticks have some proper earned wear to them and I was more curious at if those grips improve accuracy or not.
    Rep Points: 1455
    November 29th, 2024
    12:37 AM
    All depends on your playing style, doesn't matter which you get it'll take some adjust to like everything. If you get the longer sticks it makes it so you move your thumb less to move the camera more, on my SCUF I have short concave extra grip stick on the left stick, and medium convex regular grip on the right stick.
    Experience: 215,525
  9. #19
    Thrixo's Avatar
    Rep Points: 2790
    November 29th, 2024
    10:37 AM
    belgium
    just gotta find out what works best for you.. different for everyone.
    Experience: 436,938
    CAGCLAN.com Is The Official Site Of The CAG Clan And Its Gaming Community With Discussion Forums For The Casual And Hardcore Gamer!
The #1 Clan Is Secured By:
