Page 2 of 12 FirstFirst 123456 ... LastLast
Results 11 to 20 of 112
Thread: Class Loadouts For AW?
    Beastmode's Avatar
    May 9th, 2025
    02:07 AM
    Janesville, WI
    Here's a few and I'll give you the situation
    ASM1
    Stock, Foregrip, Red dot (I customed this to your play style, I typically run quickdraw or extended mags for better kill feeds)
    I also have one with Stock / Quickdraw / Advanced Rifling
    Lightweight, Gungho with Toughness and Scavenger.
    I typically use this class for more MR maps. The ASM1 is by far one of my favorite SMG's in the game for this. If you can pop shot it from MR / LR you can still get the kills.
    KF-5
    Same setup as above. The only difference is this is your CQC maps only. The KF5 is useless if you don't plan on being right up in the Enemies face. If you're anything like me that's your sometimes preferred playstyle and up close there's not a gun that melts better aside from maybe the MP11 Goliath.
    Bal27
    Attachments: Foregrip, Extended Mags, Stock
    Kill streaks remain the same
    This is probably by far my favorite class. Even with the nerf to the Bal it is still one of my favorite guns in the game. It's diverse in the fact that it allows you to switch up your play style with out switching out your load out.
    Now, I also have an ASM1 / Bal-27 class that assists with going for DNA bombs. I typically run low profile and cold blood on that class with the same attachments and the Killstreaks being a hyped UAV with threat detection red arrow and a System Hack with Extra Time, Disable Exo Suits and Flash on it.
    This is for more defensive play obviously but allows you to play more aggressive once you get your UAV unlocked. You can chose to put extra assists on your UAV to carry you to your System hack if you'd like I typically do as once the UAV goes up people get slayed on the opposing team.
    Experience: 7,478,602
    Beastmode's Avatar
    May 9th, 2025
    02:07 AM
    Janesville, WI
    Btw once you get your UAV on those play a little more defensively with the extra assists you should be able to get carried right to your System hack and then your System Hack will carry your to your AI controlled Warbird. I'm not saying hide but play more defensively.
    RainyDaiz's Avatar
    Rep Points: 45509
    May 8th, 2025
    10:07 PM
    Alaska
    I'm digging on the IMR, I forget which variant... My second choice is the duel weilded SMG vector lookalike, variant J.K. It's suppressed, and has amazeballs range for an SMG hipfire only... Combined with mute and stim, WOW! It wrecks.
    I noticed you play paintball QU33N, speedball, woods all, or scenario games? I'm trying to put enough up to make a CAG private event down here in Harford co. Maryland.
    Pondered upon a rainy plateau, with a coal forge, and many dragon.
    iForge
    Experience: 7,003,819
  4. #14
    QU33N's Avatar
    Rep Points: 38143
    May 8th, 2025
    11:07 PM
    new york
    I usually hold my uav til i have that and my system hack then i get a few kills. Use those and get my final streak ( when im running a 3rd) as far as that kf5 set up i may have to try it out on hardcore. Sadly i sold my mp11 goliath before i heard that it was a good gun. I used the basic of it and it just wasnt for me. I do wanna give it another chance though. Ur bal class is almost the same as i normally run it i just dont use the stock. Im lovin ur ideas here tho. Def gonna try a few of these when i jump back online.
    Experience: 1,614,104
    RainyDaiz's Avatar
    Rep Points: 45509
    May 8th, 2025
    10:07 PM
    Alaska
    Lol, must've hit post at the same time
    iForge
  6. #16
    QU33N's Avatar
    Rep Points: 38143
    May 8th, 2025
    11:07 PM
    new york
    Quote Originally Posted by RainyDaiz View Post
    Im using the IMR impact mostly. I believe its +1damage and mobility. Not 100% sure. But its pretty good...i kinda prefer the feedback. That one is absolutely flawless for me seeing as it has a faster fire rate to it. And if i even attempt to use duels i shoot everything except my target. Please explain to me how in the hell u get good with those damn things.
    QU33N's Avatar
    Rep Points: 38143
    May 8th, 2025
    11:07 PM
    new york
    Oh. And i play all. Mostly woods but speedball has always been really fun for me. It really depends on the gun im using at the time on which i prefer.
  8. The Following User Says Fucking Hell Yeah ! to QU33N For This Fucking Post:
    RainyDaiz (January 13th, 2015)
  9. #18
    RainyDaiz's Avatar
    Rep Points: 45509
    May 8th, 2025
    10:07 PM
    Alaska
    I run a hipfire class, and play sneaky running up flanks. Mute and Stim help this greatly. There's some recoil to compensate for, but that's all in practice to learn how far down to pull on it. I had a 16-0 streak with the J.K. Variant runnin' and gunnin'. If I'm close, I just lay out a clip, if not, it's more of a tap-fire deal. Suppression that comes on that variant helps; as they won't know where you're shooting from at first.
    Now if only they could make a suppressor for the Evol Angel marker I run...
    iForge
  10. #19
    QU33N's Avatar
    Rep Points: 38143
    May 8th, 2025
    11:07 PM
    new york
    I may have to try that out with mute and cloak. Im not sneaky enough. Im always the one you see running straight up the center of the map and going for the first few kills. I always run overclock so i can get there before the enemy and wait.lol
    Ginger Kid 138's Avatar
    Rep Points: 1580
    May 9th, 2025
    07:07 AM
    England, lincolnshir
    I'm a player that will attack you straight on I run over lock so I can get to the middle of the map first and get set up for first blood, as QU33N might back my up in most of my game I get first blood and go on a good kill streak from there. Was playing about 30 minutes ago and joined a game late, was on a 16 gun streak and my team mate killed me not pleased at all but rainydaiz you sound like a player that could be a bit of a handful of you wasn't watching out for people flanking.
    Experience: 761,867
