Results 1 to 10 of 16
Thread: Computer Problems
Discuss general topics about CAG's PC Division here
    RainyDaiz's Avatar
    Rep Points: 45509
    May 9th, 2025
    12:41 AM
    Alaska
    Computer Problems
    As some of you know, I have had computer problems since before I joined CAG... I had it up and running today! And then it made this weird squeaking "bug in an electric racquet" screechy noise from the tower case; and then it started displaying squares and rectangles on the screen, fist in blues, then it went black, then to green, then black, and then back to blues... After that the CPU shut down, and it will not turn on.
    I run an ASUS Guru mobo, and it is displaying 9.6 on its diagnosis LCD. I have unplugged the power supply unit, in case it's a short.
    Pondered upon a rainy plateau, with a coal forge, and many dragon.
    iForge
    Experience: 7,004,005
    MagnaLudus's Avatar
    Rep Points: 1185
    May 9th, 2025
    04:41 AM
    Virginia
    Any idea what the sound may have come from? PSU, CPU Fan? Does the PSU smell burnt?
    Have a plan to kill everyone you meet
    CAG Dogg Level: 27 [?]
    Experience: 138,144
    Next Level: 157,092
  3. The Following User Says Fucking Hell Yeah ! to MagnaLudus For This Fucking Post:
    RainyDaiz (January 9th, 2015)
    RainyDaiz's Avatar
    Rep Points: 45509
    May 9th, 2025
    12:41 AM
    Alaska
    No odors emanated from the tower, but I have no idea where the sound came from... I do know it was lower in the tower, so not from fans or PSU. Could've been the coolant pump, or possibly the HDD *cringe* I'm hoping coolant pump, because the CPU is set to shut off BEFORE any damage could be done, upon faults with the cooling system... I'll probably crack it tomorrow and start individually testing to find the problem.
    iForge
    RainyDaiz's Avatar
    Rep Points: 45509
    May 9th, 2025
    12:41 AM
    Alaska
    I can't get it to POST but I have managed to get some debug codes fired off...
    86- OEM DXE initialization Codes.
    96- PCI Bus Assign Resources.
    And 9F- Reserved for future AMI Code.
    iForge
    RainyDaiz's Avatar
    Rep Points: 45509
    May 9th, 2025
    12:41 AM
    Alaska
    I just realized this is NOT in the forum I intended it to be in. Could it possibly be moved to the PC Division Gen topics?
    iForge
    May 9th, 2025
    05:41 AM
    Beyond my level of PC knowledge, not much of diagnostic dude TBH. Thread has been moved as per requested however.
    Experience: 49,877,715
  8. The Following User Says Fucking Hell Yeah ! to BlameItOnGod13 For This Fucking Post:
  9. #7
    RainyDaiz's Avatar
    Rep Points: 45509
    May 9th, 2025
    12:41 AM
    Alaska
    Thanks Blame. I'm just looking for any advice I can get. Not much of one myself... Just educated-ish guesses.
    iForge
  10. The Following User Says Fucking Hell Yeah ! to RainyDaiz For This Fucking Post:
    BlameItOnGod13 (January 9th, 2015)
  11. #8
    MagnaLudus's Avatar
    Rep Points: 1185
    May 9th, 2025
    04:41 AM
    Virginia
    Ok, just so we are on the same terminology. By POST you mean not even the bios runs or meaning it will not boot the OS?
    The PCI Bus error leads me to believe something you have plugged in to a PCI-E slot is bad. I don't see the INIT error being an issue for trying to get it to boot. I would start by removing all cards inside connected to motherboard (video, sound, usb, firewire, etc). Boot without the video card as well and listen for beeping error codes or if your mobo has it then look at the LCD readout. If the you get an error and it comes back as video then insert your video card as normal and try to boot. If you continue to get an error change the slot in which the video card is in. If you have only 1 PCI-E and the rest are 8x or 4x dont worry as it will still operate just fine. Hopefully this helps
    Experience: 138,144
    Next Level: 157,092
  12. #9
    RainyDaiz's Avatar
    Rep Points: 45509
    May 9th, 2025
    12:41 AM
    Alaska
    The only thing "running" is the diagnostic LCD readout on MoBo; that's where the nostic codes came from that I looked up in MoBo's manual. PSU doesn't kick over, fans are off-line, no L.E.D. Status lights fire; just the LCD readout.
    The strange thing being I don't have ANY PCI slots of any kind, lmao. I will still try booting with no cards attached, and just the O.S. H.D.D. This was my first plan of action, so am happy to have it corroborated.
    iForge
  13. #10
    MagnaLudus's Avatar
    Rep Points: 1185
    May 9th, 2025
    04:41 AM
    Virginia
    What are your machine specs? mobo,cpu,video, etc
    Experience: 138,144
    Next Level: 157,092
Members who have read this thread : 9
