Page 1 of 7 12345 ... LastLast
Results 1 to 10 of 67
Thread: Levelbf 5v5 Defuse Tournament (BF SnD)
    April 27th, 2025
    05:43 AM
    got this in an email today. if anyone wants to get a team going with me, let me know. if you plan on doing this with me we will have a mandatory minimum of 2, preferably 3 or 4 practices per week. if you can't practice i'll get a team going with some buddies who will. here's the info. XB1 only.
    Hey Battlefielder,
    5v5 Defuse Tournament Announcement:
    Level Battlefield 5v5 Defuse Tournament with a $200 prize pool and prizes on the Xbox One. More information will be available in the coming weeks on youtube channels and twitters. We are constantly working on providing you with the best DEFUSE tournament event as possible.
    LevelBF 5v5 Defuse Tournament Rule Set
    Event Details
    This is a 5v5 Defuse one day tournament we are hosting for the Xbox One community! We expect this event to work out, but this is a test cup and we expect there to be some problems that will arise during the event. We hope you continue to stand with us as we bring you this event.
    Date: March 1stTime: 1PM EST/7PM UTC (Team participants need to show up no later than 30 minutes before start.) Watch it LIVE: www.twitch.tv/levelbf
    Bracket: Coming Soon
    Prizes & Stream Giveaways
    First Place-(5) Elgato Game Capture HD-$200
    Second Place
    -(5) $20 Steam/PSN/XBL (Provided by Brass Monkeigh Apps)
    Stream Giveaways-One Elgato Capture HD-Brass Monkeigh App codes for stream giveaways
    Rules: -Captains must join TS Servers
    Two team captains will be on teamspeak prior to match start. During this time one designated Team Captain will join a defuse server, after which the number of the server will be given to the team captains so that each team can join. An admin will select which Team Captain will select a server. This will be done quickly and without delay. If a team delays to get their 5 in the server within 15 mins, that team will forfeit.
    - In the event of an American Team matching up against a European team, the match will be played on an EAST US SERVER.
    - If the team match is an American Team versus an American Team the match will be played on an EAST US SERVER.
    - If an European Team matches up against a European team, the match will be played on a EUROPEAN SERVER.
    Player/Team Requirements-5 players must be present to play the match. Anything less will result in a forfeit.-Players must be from North America or Europe
    Match Procedure
    -Captain or team member must join TeamSpeak 30 minutes prior to tournament start time. Failure to do so will result in your team being removed from the tournament and a reserve team taking your place.-Three maps will be played. 6 rounds per map (3 attacks/3 defends)-In the event of a tie, a sudden death will occur. It will go to a fourth map where one round will be played (1 attack/defend) The winner of this round will win the match. Example: the first team to score on the first bomb/round wins the tiebreaker on the fourth.-Round time of 4:00 will be in place
    Switching Players In Match
    Both teams are allowed to substitute players after each round.
    Disconnects (Player Drops)In the event of a player drop, that player can reconnect, or that player can be substituted. Play will continue in the event of a player drop.-You have 10 min after the match time to get into your next match if you do not make it by then you will be disqualified unless it is because of a previous match running late or the tournaments at fault.
    Match ResultMatches are to be played Best of 3 without the event of a tie. Each map win is 1 point, a tie is 0 points for both teams and a loss is 0 points. First team to 2 points.
    MapsMap type & size: Defuse or Infantry Only Defuse
    (Size 10)
    Siege of Shanghai
    Hainan Resort
    Dawnbreaker
    Rogue Transmission
    Zavod 311
    Lancang Dam
    Operation Locker
    Paracel Storm
    Unlock/Weapon Restrictions
    Grenades:
    • No minis
    Guns:
    • No shotguns
    • No DMR’s
    • No As Val
    Equipment:
    • Only M320 allowed is smoke
    • No Engineer Equipment
    • No C4
    • No Claymore
    • No Airburst
    • No Recon Equipment (If you spawn in as recon, select no gadget for both gadgets to avoid any disqualification.)
    Maps:
    • No rooftops on Shanghai and Zavod
    The use of restricted weapons or locations will be punished by a forfeit of match. Any team wishing to file a petition for a rule violation must do so before the start of the next match.
    If you come across someone potentially violating a rule, simply make a recording and report it to an admin immediately.
    Match Contingencies
    - If the servers crash, rejoin a new server and continue a new map.
    Example, if Team A wins Map 1, and the server crashes on Map 2, restart Map 2 as a fresh restart, regardless of the score during Map 2.
    - If non team players join into your server either ask the person to leave politely over messages. If the player does not leave within 2 minutes, leave the server and find a new one. Continue where you left off, example if you won map 1 and random joins during Map 2, restart Map 2.- If any glitches occur, ie. Randomly going up by 3 rounds to 0 at the start of a game, or starting off with a bomb already armed, burn the map, the entire map and start new a new fresh- Burning the map means you allow the map to be won by either team, it will not count for the final score. Default the map, if you have any questions regarding please respond to this email. - ANY OTHER THINGS NOT MENTIONED HERE WILL BE ADDRESSED AT THE TEAM CAPTAIN MEETING FEB 22nd 12:00PM EST- Admins reserve the right to change any rules prior to match start date.
    Confirmation email will be sent to teams who have signed up.
    Feedback Survey after the completion of the event. In the event of rule breaking, submit video evidence to levelbattlefieldx1c@gmail.com. Update prior to match will be sent via email to the team captains. Follow up by Taylor, Dan, or Wally during that week to confirm the team captains have seen the email. Weekly youtube video describes the latest tournament updates, promotional content, and other general information.Round One check in is one hour prior to your match start time. For all other rounds, the team captains must check in on Teamspeak 20 minutes prior to the match. These check in times are mandatory. If you do not check in, you will be disqualified.Once they are on Teamspeak, they will remain in teamspeak. They will check in with their assigned admin, and confirm match rules, players, and times.
    Team Roster: Current As of 2/8/2014
    Uprising EU
    Aequitas Veritas US
    Utopie Madness EU
    iCoNiC US
    Team PyRoGEN EU
    Lucky Strike US
    NoName.SynerGy EU
    One Nation US
    InFamouS.ReDeMption EU
    Carbon US
    Quee EU
    CrypTic US
    Team Evolve EU
    GTL US
    Xtreme Gaming EU
    KozmyK US
    The A-Team USTeam Sinister USTeam 6 USThe Business USNaptown Heroes US
    Information Sources: To keep up to date on Tournament Information, visit any of the following sources. Any and all questions should be sent to our email: Levelbattlefieldx1c@gmail.com
    We highly recommend you visit the forums and introduce yourself in the Xbox One Section
    Level BF Forums: https://levelbf.com/forum/
    Experience: 49,745,602
  2. The Following 3 Users Said Fucking Hell Yeah ! to BlameItOnGod13 For This Fucking Post:
    CAG JB (February 9th, 2014),CelticSaint (February 8th, 2014),Emperor XIX (February 11th, 2014)
    CelticSaint's Avatar
    Rep Points: 35576
    April 27th, 2025
    04:43 AM
    Connecticut,USA
    Re: Levelbf 5v5 Defuse Tournament (BF SnD)
    I'm In
    Sent from the Saint
    Experience: 5,464,642
    April 27th, 2025
    05:43 AM
    you only play on weekends right?
    Rep Points: 35576
    April 27th, 2025
    04:43 AM
    Connecticut,USA
    Fri-sun due to night classes
    Sent from the Saint
    April 27th, 2025
    05:43 AM
    i gotta see what works best for everyone as far as practice goes.
    Rep Points: 35576
    April 27th, 2025
    04:43 AM
    Connecticut,USA
    Ok no problem
    Sent from the Saint
  8. The Following User Says Fucking Hell Yeah ! to CelticSaint For This Fucking Post:
    BlameItOnGod13 (February 8th, 2014)
  9. #7
    April 27th, 2025
    05:43 AM
    no one else interested?
    Rep Points: 35576
    April 27th, 2025
    04:43 AM
    Connecticut,USA
    They don't read the forums
    Sent from the Saint
    April 27th, 2025
    05:43 AM
    just something to consider for anyone who may read this but doesn't like that game mode... if you have never played competitively and are interested in it or plan on doing so for BF4, i would take every opportunity to get used to doing so. it is completely different from pub stomping. you won't be able to kill 5 guys because the second, third, fourth and fifth didn't notice the first guy go down. you can't get away with running a train without a suppressor because the other team doesn't have mini map awareness or never look at it. there is no such thing as one person capping a flag or armor capping flags.
    everyone on the opposite team will be communicating at all times and will be watching the mini map. they will all be playing the objective. they will be using strategies and tactics. you can expect to play against the best players. every opponent will be using try hard weapons at all times.
    i really, really hope Celtic and myself aren't the only people in this clan that play BF interested in playing competitively.
  12. The Following 2 Users Said Fucking Hell Yeah ! to BlameItOnGod13 For This Fucking Post:
    CelticSaint (February 9th, 2014),MYKMANSUN77 (June 1st, 2014)
  13. #10
    pisspawz's Avatar
    Rep Points: 11110
    April 27th, 2025
    05:43 AM
    Six Nations Ont Canada
    I'm in as long as these games are not through the day as work will interfere
    Experience: 23,214,682
  14. The Following User Says Fucking Hell Yeah ! to pisspawz For This Fucking Post:
    BlameItOnGod13 (February 9th, 2014)
