Results 1 to 4 of 4
Thread: Engineer Class Gun Setups
Discuss the Battlefield Series here
Kujeaux Engineer Class Gun Setups September 4th, 2013, 04:13 PM
DEF4LT515 If you use a silencer with... September 5th, 2013, 09:04 AM
nadav22 I use the engineer a lot!... September 5th, 2013, 11:46 AM
hydroracer65r Thank you! I'm not good at... September 5th, 2013, 11:52 AM
    April 8th, 2025
    11:06 AM
    The Engineer class ... where did that intern in the Support class go? I'm out of boomsticks
    I've been doing some research on guns within each class and wanted to share what I've found. Please discuss and share some of your favorite gun setups. This isn't really meant to talk about class gadgets or squad perks though.
    Accessory 1: Scopes, tons of choices
    Accessory 2: Bipod, Foregrip
    Accessory 3: Flash Suppressor, Suppressor, Heavy Barrel, Laser Sight, Tactical Light
    Accessory Notes:
    Recommend not using Foregrip as it increases spread; recoil can be managed.
    Use dat Heavy Barrel.
    Close Quarters Guns / Setup:
    M4A1 (similar guns: M4, A-91) – M4A1 has the fastest reload and kills fast
    KOBRA (any RDS or Holo)
    Bipod or None
    Laser Sight
    Distance Guns / Setup:
    AKS-74U (similar guns: SCAR-H, QBZ-95B)
    KOBRA (your choice)
    Bipod or None
    Heavy Barrel (a must for range)
    Versatile Guns / Setup (not the best at Close Quarters or Distance but decent at both):
    G36C (similar guns: G53, SG553)
    KOBRA (your choice)
    Bipod or None
    Heavy Barrel
    Experience: 9,435,266
  2. The Following 2 Users Said Fucking Hell Yeah ! to Kujeaux For This Fucking Post:
    Mad Shot (October 22nd, 2013),StormySGT ELIAS (September 5th, 2013)
    DEF4LT515's Avatar
    Rep Points: 40694
    April 8th, 2025
    12:06 PM
    WISCONSIN
    If you use a silencer with the forgrip it reduces the spread along with vertical recoil. The only downside is the range is less and more bullets for a kill, kinda wish you could use a heavy barrel with the silencer.
    Experience: 6,545,961
    nadav22's Avatar
    Rep Points: 3535
    April 8th, 2025
    08:06 PM
    israel
    its awesome!
    Experience: 1,011,155
    hydroracer65r's Avatar
    Rep Points: 560
    April 8th, 2025
    09:06 AM
    United States
    Thank you! I'm not good at setting up classes lol. I just do what ever seems to work! Haha
    Sent from the Grinches Lair!
    Experience: 213,482
Members who have read this thread : 1
