Results 1 to 10 of 14
Thread: HELP with a car problem
Discuss featured articles, topics from Games, Videos, Jokes, Stories & Entertainment here! News about XBOX, PS3, WII, Movies, Hollywood and Music can be found here. You can also share your favorite jokes and comic strips here as well!
    StormySGT ELIAS's Avatar
    Rep Points: 56618
    February 21st, 2025
    07:48 AM
    Chicago, IL
    I have a problem with a Ford windstar 2001 if I let it sit 2 days it wont crank after trouble shooting it I have replaced the starter probably wasn't needed but this is my problem any ideas much appreciated so I took of the serpantine belt disconected the starter (Took it off) and turned the pully with like 90 lbs. of pressure i turn it till it gets stuck and when i get it past that area I put the starter back on put on the serpantine and she'll crank runs very smooth conected the computor to it no codes every body is baffled can't figure whaz up it will start no problem I turn it on and turn iy off 20 times or more still no problemtill I let it sit yes I have a new 3 mounth old battery
    CAG Stormy SGT ELIAS
    Experience: 12,508,699
    jDIAMOND's Avatar
    Rep Points: 3635
    February 21st, 2025
    07:48 AM
    Warren, Ohio
    Where is SHOWINGNONE when u need him
    Sent from my PG86100 using Tapatalk 2
    CAG Dogg Level: 52 [?]
    Experience: 15,649,299
    Next Level: 16,259,327
  3. The Following User Says Fucking Hell Yeah ! to jDIAMOND For This Fucking Post:
    CAG CheechDogg (June 6th, 2013)
    TORCUT's Avatar
    Rep Points: 2185
    February 21st, 2025
    05:48 AM
    Ukiah, CA
    It wont turn over at all?
    It could be your alternator isn't putting out enough power to your battery.
    Also, anything that uses power in your car, power windows, windshield wipers etc. could be faulty. I remeber my buddys car would never hold a charge. Overnight it would'nt turn on. We figured out there was a glitch in the power windows that was draining power 24/7, even if the car is off.
    So we took out the fuse from the fuse box that controlled the power windows, disabling them, and the problem was fixed. His windows dont work now but it was a cheap fix.
    Experience: 492,732
  5. The Following User Says Fucking Hell Yeah ! to TORCUT For This Fucking Post:
    BlameItOnGod13 (June 3rd, 2013)
    The Amorbis's Avatar
    Rep Points: 1435
    February 21st, 2025
    05:48 AM
    Steamburg
    Yeah I was gonna say check your fuses n what not.. pull a couple out at a time to test things out lol... very inconvenient.. but cheap
    CAG Dogg Level: 32 [?]
    Experience: 379,320
    Next Level: 453,790
    BigD4addy0's Avatar
    Rep Points: 1060
    February 21st, 2025
    06:48 AM
    Edmonton, Alberta, Canada
    I know your battery is only 3 months old, but you should get a load test done on it. The battery may be faulty, at the same time you can check the output on your alternator. if you find the battery is weak, then you should be able to get a warranty replacement. Make sure to clean all your connections to the battery and alternator this should help.
    Another thing, do not disconnect the battery before checking for codes. This will wipeout all the codes.
    I hope this helps,
    CAG Dogg Level: 30 [?]
    Experience: 285,218
    Next Level: 300,073
  8. #6
    CAG Saki333's Avatar
    Rep Points: 6685
    February 21st, 2025
    04:48 AM
    Kihei, Hi
    Quote Originally Posted by StormySGT ELIAS View Post
    Check for spark, if you have spark, check for fuel, is you got fuel, check the mass air flow sensor to make sure it is working. if all that is good then it could be your crank sensor. let me know what you got
    My kung fu is better than your kung fu....wwwaaaattttaaa!!
    Experience: 1,718,034
    Rep Points: 6685
    February 21st, 2025
    04:48 AM
    Kihei, Hi
    let me ask you does your car have an anti theft device under the steering wheel right above the foot pedals? FORDs are famous for putting these in, I have seen these come out and there is nothing, it would look like a almost a sd card, black almost triangular shape and it can only go in one way. check it out
  10. The Following User Says Fucking Hell Yeah ! to CAG Saki333 For This Fucking Post:
  11. #8
    Cobra_Str1ke's Avatar
    Rep Points: 710
    February 21st, 2025
    06:48 AM
    missouri
    the alternator gone bad or battery is defective, my dad has the same van and same problem happened but i could be wrong and could be something else.
    Experience: 243,981
    Next Level: 300,073
  12. #9
    February 21st, 2025
    04:48 AM
    It's a FORD that's the problem....Fix Or Repair Daily = FORD ...
    Experience: 288,911,032
  13. The Following 2 Users Said Fucking Hell Yeah ! to CAG CheechDogg For This Fucking Post:
    Cobra_Str1ke (June 6th, 2013)
  14. #10
    Sidebangx's Avatar
    Rep Points: 49077
    February 21st, 2025
    04:48 AM
    Washington State
    There must be something wrong with your Space time continuem module..whats that? You dont have a Space time continuem module? Something might be wrong with your tractor beam.. you dont have one? Did you check your unicorn engine? The unicorn is at magic mountain? Well thats your problem right there...
    Lol but really the thing thats messing it up is probably the most obvious.. A fairy god mother takes it for a joy ride every other day leaving it all bunkered out. Am I trolling to hard? I feel like I am. My bad. I really couldnt help you bro :/ Sorry.
    -I done wrestled with an alligator!
    -Done tussled with a whale!
    -I Handcuffed lightning!
    -And threw thunder in jail!
    -Ive murdured a rock!
    -Injured a stone!
    -Hostpitalized a brick!
    Im so Bad I make medicine sick. Im gon' Show you! How great I am.
    "Whatcha' gon' do, When the CAG Doggs come for you?"
    CAG Dogg Level: 43 [?]
    Experience: 3,151,815
    Next Level: 3,609,430
