Results 1 to 1 of 1
Thread: My HC TDM PDW setup
    April 22nd, 2025
    10:44 PM
    My HC TDM PDW setup
    ok the tips and tricks was great and very informative. well done showing i believe? but i had alot of questions as you can see. not being a PR i just want to try and help anyone anyway i can. make you better makes us better. so im gonna go through my whole setup, explaining how and why i use everything. this is my PDW class for HC TDM.
    Wep is PDW or as i call it the PDdub.
    attachment i always use is reflex. i personally cant use the iron sights on the PD.
    second attachment ill use maybe faster reload at times, sometimes grip if its gonna be a ranged battle. never messed with faster rate of fire much. mostly i just run the reflex and nothing else so i can use all the things listed below. a second attachment is a vary of my main build.
    Secondary ill use the first launcher, i forget the name. if i have the space in the loadout. its just another way to vary the loadout to make you more flexible on your own.
    occasionally i use danger close if im by myself and need the extra lethal. otherwise i avoid having to take up 2 spaces of my 10. otherwise i use double perk 2 ALWAYS.
    perk 1 is blind eye. always, never fails. use it to survive.
    perk 2 is always scavenger and cold blooded. scav to pick up lethals, ammo for first and secondary and tacticals. this is USEFUL EVERYWHERE! i guess im still taking up 2 spaces by using double perk 2 and a second perk, but i would rather resupply everything once for each kill then start with an extra lethal.
    perk 3 is engineer. infinitely useful for surviving on HC.
    lethal i run a betty. mostly use them defensively. even if they get destroyed or hacked, if its in front of the only entrance to you, you know the enemy is not to far off. be ready and you should get the kill 8 out of 10 times.
    tactical i use shock charges x2. defensively again to cover areas my betty cant. listen and be ready and it should be a freebie for you or your team. again, if they get destroyed or hacked you should have a good idea of where the enemy is coming from if you place them correctly. IE in a doorway.
    i use this setup for HC TDM never fails. i almost always go positive and sometimes REALLY positive. try it or not, its just a suggestion. practice this set up along with placement of your betty and shock charges and you'll do fine. this is a great defensive setup i find. good for tacticly waiting. try to rack up as many gun kills as possible to refresh your betty and shock charges. i find that if i have a betty already out and im runnin and gunnin, which you can with this setup i find it versatile, get a gun kill, another betty and strategicaly plant it. i once had 7 bettys in one life cycle. using 1 betty to start. any questions/comments/suggestions? feel free to reply. please do, i'm always looking for a fresh perspective.
    Experience: 49,698,354
  2. The Following 2 Users Said Fucking Hell Yeah ! to BlameItOnGod13 For This Fucking Post:
    CAG CheechDogg (January 30th, 2013),StormySGT ELIAS (January 30th, 2013)
