Thread: Black Ops 2 II - Create-A-Class
Discuss all topics concerning the Black Ops series here
    February 10th, 2025
    02:40 PM
    The Black Ops 2 Create-A-Class has been completely revamped and updated. The multiplayer Create-A-Class features a new 10 point system, also referred to as "Pick 10", which gives you 10 allocation points to use on weapons, equipment and perks.
    Each weapon, weapon attachment, perk, and equipment uses 1 allocation point, but you can only spend 10 allocation points per class - you, of course, get to choose what you take on the battlefield. If you don't use perks, that saves you 3 points, which can then be used to equip more weapon attachments or grenades. You could also carry only a secondary weapon with 2 attachments, have 4 perks, and one grenade.
    The choice is yours.
    Source: http://www.blackopsii.com/bo2/create-a-class/
    Wildcards
    You can also optionally choose up to 3 Wildcards for your class, which in turn give various options to customize your class even further. For example, by default your primary weapon can be equipped with 2 attachments, but with the Primary Gunfighter Wildcard the weapon can be equipped with 3 attachments.
    Each Wildcard uses 1 allocation point.
    NOTE: Some Wildcards, like the perk greed, "require" you to select an additional perk, which also uses 1 extra point. If you want to have 6 perks, the first 3 perks require 3 points, after that each additional one requires 2 points (1 for the Wildcard + 1 for the perk), for a total of 9 allocation points - this of course leaves you only with 1 point to spend on a weapon.
    Primary Gunfighter
    primary gunfighter wildcard 3Allows you to equip a 3rd attachment to your primary weapon.
    Secondary Gunfighter
    secondary gunfighter wildcard 3Allows you to equip a 2nd attachment to your secondary weapon.
    Overkill
    overkill wildcard 3Allows you to use your primary weapon as a secondary weapon.
    Perk 1 Greed
    perk 1 greed wildcard 3Allows you to choose 1 extra perk to the Perk 1 slot.
    Perk 2 Greed
    perk 2 greed wildcard 3Allows you to choose 1 extra perk to the Perk 2 slot.
    Perk 3 Greed
    perk 3 greed wildcard 3Allows you to choose 1 extra perk to the Perk 3 slot.
    Danger Close
    danger close wildcard 3Allows you to take a second Lethal equipment.
    Tactician
    tactician wildcard 3Allows you to choose a Tactical grenade in place of your Lethal grenade. This Wildcard doesn't allow you to carry any Lethal equipment.
    Experience: 288,494,041
    February 10th, 2025
    10:40 PM
    This system is going to be one of the more complex systems with so many ways to really customize so good that you may rarely see your setup online,
    The route I'm taking is that I'm going to have 1-2 strong classes then the traditional support classes and/or perimeter (2 claymores etc). Highly doubtful ill use a secondary if that ...
    Experience: 35,734,661
    zack eckley's Avatar
    Rep Points: 685
    February 10th, 2025
    11:40 PM
    Grimsby,UK
    Hey i just wanted to share with you all my best class
    peacekeeper reflex sight and silencer
    perks
    extreme conditioning
    scavenger
    enginer and dexerity
    you all should try it and see if you like it aswell also i could do with a few classes to try so inbox me you best classes
    Experience: 322,892
  1. Black Ops
    By Eagle7 in forum General Topics
    Last Post: December 3rd, 2012, 05:22 PM
Members who have read this thread : 5
