Thread: Mw3
COD Forums to discuss Black Ops 2, Black Ops, MW3, MW2 and other Call of Duty games
    TKO x Achilles's Avatar
    April 24th, 2025
    07:04 PM
    Bowling Green KY
    Sickshit Mw3
    Hey guys i just recently joined CAG looking for ppl to play MW3 with hit me up!!
    CAG Dogg Level: 14 [?]
    Experience: 4,700
    Next Level: 5,517
    April 24th, 2025
    04:04 PM
    Make sure you fill out an application and you check out the following information:
    ATTENTION NEW APPLICANTS AND RECRUITS
    If you just recently submitted an application to join CAG you must make sure you check back in your application thread for further instructions. Use your application thread as your main communication portal if you have any questions regarding your application.
    Each Division's Commander or a Recruiter will give you further instructions on what you need to do in order to begin your recruitment process. If you do not check your application thread you will miss further instructions and delay your recruitment process. Below is each Division's Commander and a direct link to send them a friend request or private message on xbox live.
    MW3 ( COD Series )Division Commander - CAG SYKO MENACE
    BF3 ( Battlefield Series )Division Commander - DEATHvern0
    GRFS ( Tom Clancy's Series ) Division Commander - CAG OuttaTime
    "DO NOT" send a private message to any of the Site Admins, or the Clan Leader about the status of your application, you "WILL NOT" get a response back that way.
    Also make sure you are as active as possible on the forums, make sure you read the History of CAG, Chain of Command, Code of Conduct and check out the Clan roster.
    Experience: 291,236,143
