Results 11 to 15 of 15
Thread: Exacto Ammo
Find all the weapons, equipment used in Ghost Recond Wildlands here and all the unlocks and achievements as well!
    March 22nd, 2025
    11:13 AM
    Where did you find out about this Dae?
    Experience: 289,992,418
    Paladin Xenos's Avatar
    Rep Points: 310
    March 22nd, 2025
    12:13 PM
    ive only ran into exacto ammo once and didn't think it was a big problem but i can see where your coming from.
    Experience: 313,826
  3. #13
    Crazy x Sauce's Avatar
    Rep Points: 1525
    March 22nd, 2025
    02:13 PM
    Boston, MA
    Quote Originally Posted by Paladin Xenos View Post
    It's been fixed with the last update
    Sent from my HTC One X using Tapatalk 2
    Experience: 2,979,585
    March 22nd, 2025
    11:13 AM
    I have actually not had any problems with exacto ammo the last few times i have played.
    The way it should work should be like this.
    If you have spotted your target, the bullet should not be able to turn corners at all. What it should do if it already doesn't do it is just be able to turn enough like a heat seeking missile. Even those can not turn corners. If you are out in the open of course that bullet should get you all the time, but if you are behind cover it should not even be able to hit you at all, unless you are say between 5-10 feet behind cover to give the bullet enough time to turn and then hit you.
    Rep Points: 1525
    March 22nd, 2025
    02:13 PM
    Boston, MA
    I agree the only way I see it is if your aiming to the right left down or up of the target it helps to hit the target but then it shouldn't always end up in a headshot just enough to hit somewhere on the target
