Thread: GRFS Launchers
Find all the weapons, equipment used in Ghost Recond Wildlands here and all the unlocks and achievements as well!
    April 20th, 2025
    08:24 AM
    GRFS Launchers
    These are all the Launcher weapons in GRFS, these are brought to you by http://www.imfdb.org/wiki/Main_Page
    Launchers
    Brügger & Thomet GL-06
    The Brügger & Thomet GL-06 appears as "Gl06" and can fire smoke, EMP, and frag grenades.
    400px B26T GL 06 magnify clip
    B&T GL-06 - 40x46mm
    600px Grfsgr magnify clip
    Weapon selection view.
    CZ 805 G1
    The CZ 805 G1 is the under-barrel launcher used by Bodark in the MP.
    400px CZ 805 G1 Stand Alone magnify clip
    CZ 805 G1 Stand-Alone - 40x46mm
    600px GRFS UBGL magnify clip
    FN 40GL
    The FN 40GL (Mk 13) appears as "Mk40GL" and can fire smoke, EMP, and frag grenades. It is a secondary weapon, used by the Scout class. Also available as an under-barrel attachment for assault rifles.
    401px FN40 magnify clip
    FN MK 13 (EGLM) in Standalone configuration - 40x46mm
    601px GRFS 40GL magnify clip
    600px GRFS GL1 magnify clip
    40GL under-barrel attachment
    Experience: 291,062,617
    April 20th, 2025
    08:24 AM
    More info on launchers in GRFS
    Ghost Launchers
    Mk40GL EMP
    It’s a secondary EMP launcher that fires 40MM EMP shells. These shells explode after traveling some distance from the ground. A direct hit can temporarily knock out the enemies.
    Mk40GL Expl.
    It fires shells that explode on the impact. It takes almost 4 seconds to reload this launcher.
    Mk40GL Smoke
    It is quite similar in action to the launchers mentioned above. The only difference is that if fires Smoke Shells creating a smoke screen on explosion.
    April 20th, 2025
    08:24 AM
    Ghost Recon: Future Soldier – Secondary Weapons
    G106 EMP
    It fires 40MM EMP rounds that explode on impact. The EMP can interfere with the normal functioning of enemy equipment.
    G106 Explosive
    This secondary launcher fires explosive shots that explode on hitting the target.
    G106 Smoke
    This secondary launcher has shots that will create a smoke screen on explosion.
