Thread: 2009-18 Ram 1500 2wd 5.7 Hemi 7" Lift Kit W/ Fox Shocks
Lifted Truck Forums to discuss any and all lifted trucks
    March 30th, 2025
    08:39 PM
    This is a Ram 1500 2wd Lift kit from Maxtrac and the one I have on my truck. There is no better way to lift your 2wd Ram 1500 other than using this lift kit. It uses 4.5" spindles up front with 2.5" coil springs and Fox 2.0 monotube shocks that make the truck ride better than the stock suspension these trucks come with.
    I know a lot of people will hate and say wtf did you lift a 2wd truck but the fact is 2wd trucks have been getting lifted since the 70s and Baja trucks are mostly 2wd anyways.
    But back to this Maxtrac lift, if you guys have any questions about this lift kit don't hesitate to ask me, I can also get you guys a very good price on this lift kit.
    M198645027Description
    The Maxtrac Suspension 7-inch lift for the Ram 1500 is a cost-effective way to lift your 2WD wheel drive truck without breaking the budget. We do this by taking a factory height spindle and lowering the wheel hub position, which in turn raises the vehicle up while maintaining a factory-like ride and turning radius. We then install a Maxtrac coil spacer on top of the factory coil spring along with a Fox 2.0 monotube shocks to complete the front lift.
    By doing this, you eliminate the need to install expensive crossmembers that are labor intensive and require factory frame cuts. The spindles come with extended, DOT compliant, stainless steel braided brake lines. The rear lift comes with Fox 2.0 monotube shocks, rear coils, track bar/swaybar brackets. The end result, you achieve a lifted truck with a leveled stance for a fraction of the cost of a standard 4WD kit.
    NOTES:
    • Track width increase of 1" per side
    • 17" Wheel or larger w/ 4 1/2 - 5 3/4 " Backspacing
    • Wheel width 8-9.5
    • Will Clear up to a 37" x 12.50 tires
    • P/N: 612400 required for vehicles with 2-piece
    This kit comes with:
    P/N: 702145 4.5" LIFT SPINDLES W/ EXTENDED BRAKE LINES DOT COMPLIANT
    P/N: 872171F 2.5" FRONT COILS & FRONT FOX SHOCKS
    P/N: 902445F 3" COILS, 1.5" SPACERS, TRACK/SWAY BRKTS, FOX SHOCKS
    Experience: 290,303,864
    05:39 AM
    Nice truck man,they dont make stuff like that over here
    Experience: 52,456,489
  3. The Following User Says Fucking Hell Yeah ! to CAG JB For This Fucking Post:
    CAG CheechDogg (August 17th, 2020)
    March 30th, 2025
    08:39 PM
    Quote Originally Posted by CAG JB View Post
    Thanks JB ! I do know a few people out that way that have lifted Rams actually..... this truck has completely taken over me lol .. always doing something to it ... follow me on Instagram if you can .... @cheechdogg.0n37s
    05:39 AM
    friend of mine had a Ranger when they first released and he put lifted rams on it but he got rid of it very quickly as he didnt expect the duel costs.
    Il check out insta
  6. The Following User Says Fucking Hell Yeah ! to CAG JB For This Fucking Post:
    CAG CheechDogg (March 21st, 2024)
    05:39 AM
    Fucking hell yea! For hell yaying my post!
Members who have read this thread : 3
