Results 1 to 6 of 6
Thread: the Division 1.2 Patch Notes
Discuss Tom Clancy's the Division here
    BIG COUNTRY's Avatar
    Rep Points: 119776
    11:40 PM
    Here are the patch notes for the new 1.2 update 5/24/16
    Just thought since I can't play this week I'll help with the info !!
    PatchNotes Header Update 1 2 251911
    The Division Update 1.2: Conflict – Patch Notes
    24/05/2016 06:31 PM
    NEW FEATURES
    New Incursion: Clear Sky
    • Clear Sky is a new Incursion mission available in Columbus Circle.
    • You must be level 30.
    • The encounter is balanced for a team of 4 players outfitted with high level gear.
    • Hard Mode is available on May 24 when the update is released.
    • Challenge Mode will be made available the week after update 1.2 launches.
    New Gear Sets
    Four new gear sets have been added.
    • Final Measure - Stand your ground by defusing hostile grenades with this powerful defensive set.
      • 2 pieces: +50% Exotic Damage Resilience
      • 3 pieces: +15% Protection from Elites
      • 4 pieces: When throwing a grenade, gain the defuse buff. When in range of a hostile grenade, the buff is consumed and defuses the grenade as well as gives you a grenade.
    • Hunter's Faith - Duel your enemies at range and come out on top with this survival focused marksman set.
      • 2 pieces: +20% Marksman Rifle Critical Hit Damage
      • 3 pieces: +20% Damage to elites
      • 4 pieces: Hitting an enemy with a bullet grants you temporary armor. The further your shot, the more armor is awarded. The armor disappears after one bullet hits you.
    • Lone Star - Never reload your weapons again with this game changing utility set.
      • 2 pieces: +100% Ammo capacity
      • 3 pieces: +1000 LMG Damage, +1000 Shotgun Damage
      • 4 pieces: When the weapon is holstered, it regains full ammo.
    • Predator's Mark - Make your enemies bleed with this powerful offensive set.
      • 2 pieces: +20% Optimal Range
      • 3 pieces: +800 Assault Rifle damage, +700 Pistol Damage
      • 4 pieces: Hit 10 shots without switching target to make the target bleed for 100% of damage already done by those bullets.
    High-Value Targets & Search and Destroy missions
    • At level 30, complete all Encounters and Side Missions in a named area to get access to the “Search and Destroy” missions in the Safe House.
    • Receive Target Intel as a reward for completing Search and Destroy missions.
    • Bring Target Intel to HVT officers at the Base of Operations to locate High Value Targets.
    • Complete daily and weekly High Value Target missions for end game rewards.
    Hijack Extractions
    • When a player attaches a bag to the extraction rope, another player now has the ability to sever the rope.
    • Severing the rope will cause all extraction bags to fall to the ground, scattering their contents as a public loot drop.
    • Be careful, hijacking an extraction will instantly mark you as Rogue!
    Sealed Cache
    • Named and Elite enemies in the Dark Zone can now drop Sealed Caches that contain mystery items.
    • Sealed Caches need to be extracted before they can be opened, just like regular loot drops.
    • There are four qualities of Sealed Cache:
      • Specialized
      • Superior
      • High End
      • Gear Set.
    Player Stash in Dark Zone Checkpoints
    • Player stashes are now available in every Dark Zone checkpoint.
    • Checkpoints stashes eliminate the need for fast travel to your Base of Operations to collect your extracted loot!
    ISAC Assignments
    • The ISAC Assignment is a new assignment type included in the map overview.
    • The ISAC Assignment will be available to players at level 30.
    • Every week a new ISAC Assignment will be available to the player.
    • The ISAC Assignment will reward players with exclusive vanity items.
    General
    • Added new high-end named weapons in the game.
      • Hungry Hog: M60 Light Machinegun
      • Centurion: M1911 Pistol
      • Medved: SAIGA12 Shotgun
      • Historian: M1A Marksman Rifle
      • (Showstopper - AA12 Shotgun): Please note that while the Showstopper will be implemented in the game with this update, it will not be acquirable in-game until update 1.3
    • The Historian high-end marksman rifle is now available.
    • Added a 201+ Gear Score bracket for highly leveled players.
    GAME CHANGES
    GAMEPLAY
    • When a player is at max level, matchmaking for Hard and Challenge mode will now only seek players that are Level 30.
    • Armor damage mitigation cap has been increased to 75%.
    • Improved weapon blind fire and overall handling while in cover.
    • Reduced damages from level 34 NPCs using Shotguns and Sniper rifles.
    • Gear Score will now only take into account the equipped weapon with the highest Gear Score, and discard the other two. This will prevent players from equipping low quality weapons to voluntarily reduce their Gear Score.
    • Increased Gear Score requirement of Falcon Lost to better represent its difficulty (note that the difficulty of this Incursion hasn’t changed)
      • Hard Mode: Gear Score 160
      • Challenge Mode: Gear Score 180
    UI
    • In the Overview of the Inventory, the Health stat above Stamina has been replaced with Toughness. This is a combination of Health and Armor. The player’s health pool will still be visible in the Character page and Stamina still increases Health.
    • The Phoenix credit cap has been increased from 1000 to 2000 credits.
    • Shooting a player while they are interacting with an object will cause the timer to push back. (such as opening a supply crate or hijacking an extraction)
    • Players now have a voice chat indicator in the game UI to see if their own VOIP works.
    • The Special Gear Vendor has been renamed Special Equipment Vendor.
    ITEMS
    • The Sentry’s Call 4 pieces talent will now only apply to semi-automatic weapons (pistols, shotguns, and marksman rifles).
    • The Second bonus on Performance Mods have been significantly improved.
    DARK ZONE
    • The extraction departure timer once the helicopter arrived has been increased to 60 seconds.
    LOOT BALANCING
    We have made a number of changes to loot drops. Specific activities will now provide the rewards listed below.
    Missions
    • Hard Mode (Boss Drop)
      • 1x 163 High End
    • Hard Mode (Mission Reward)
      • 1x 163 High End
    • Challenge Mode (Boss Drop)
      • 2x 182 High End
      • 1x 182 High End or 214 Gear Set
      • chance for 1x 191 Gear Set
    • Challenge Mode (Mission Reward)
      • 1x 182 High End
    Falcon Lost/Clear Sky
      • 1x 204 End Weapon
      • 1x 214 Gear Set
      • 182/204 High End or 214/240 Gear Set
      • Hard Mode (Weekly Reward)
        • 1x 204 High End Weapon
        • 1x 214 Gear Set
        • 1x 204 Weapon
        • 1x 240 Gear Set
        • 1x 204 High End or 240 Gear Set
      • Challenge Mode (Weekly Reward)
        • 1x 240 Gear Set
    Dark Zone
    • Added Sealed Caches as new source for loot in the Dark Zone. Caches need to be extracted before they can be opened. Caches can come in any quality starting from Specialized and contain:
      • Equipment (weapons, gear or mods)
      • Division Tech
      • Dark Zone Credits
    • Brackets 0-160 & 161-200
      • Named bosses will now have a chance to drop a High-End or Gear Set Sealed Caches. If it drops, it will replace the guaranteed High-End item
      • Elite NPCs now have a chance to drop a Superior Sealed Cache
      • Named NPC Level 30 (DZ01 and DZ02)
        • 1x 163 High End or 191 Gear Set
      • Named NPC Level 31 (DZ03 and DZ04)
        • 1x 163/182 High End or 191/214 Gear Set
      • Named NPC Level 32 (DZ05 and DZ06)
        • 1x 163/182/204 High End or 191/214/240 Gear Set
    • Added a new Dark Zone bracket for Gear Score 200+. This bracket will contain tougher enemies (level 32 to 34) and provide better rewards
      • All drops from NPCs will start at Superior quality
      • All Division Tech drops will be High-End quality
      • Higher chances to drop Sealed Caches on Elite and Named NPCs
      • Supply Drops will contain 1 High-End item Gear Score 182 (DZ 01-04), 204 (DZ 05-06) plus a chance at a Gear Set item Gear Score 214 (DZ 01-02), 214 to 240 (DZ 03-04), 240 (DZ 05-06)
      • Named NPC Level 32 (DZ01 and DZ02)
        • 1x 182/204 High End or 214/240 Gear Set
      • Named NPC Level 33 (DZ03 and DZ04)
      • Named NPC Level 34 (DZ05 and DZ06)
    BUG FIXES
    • Fixed a bug where the effects of player talents would stack when the talent was repeatedly equipped and unequipped.
    • Fixed a bug where the Reckless gear talent would increase player damage resistance instead of decreasing it.
    • Fixed a bug where the Balanced gear talent would remain active indefinitely after the weapon was shouldered.
    • Fixed a bug with the Brutal gear talent where the damage was multiplicative instead of additive.
    • Fixed a bug with the One is None character talent where the weapon could jam when the magazine was down to one bullet.
    • Fixed a bug with the Specialized gear talent where it wouldn’t account for subsequent gear changes after the backpack was equipped.
    • Fixed a bug with the Path of the Nomad talent where the Health on Kill wouldn’t work if the kill was done with a melee attack.
    • Fixed a bug with the Tactician’s Authority talent where it wouldn’t trigger properly against other Players.
    • Fixed a bug where talents that are triggered by skills could be activated by just aiming the skill instead of using it.
    • Fixed a bug where bleed resistance could roll above 100% on some items.
    • Fixed a bug where players could exit the playable map area by using the mobile cover skill.
    • Fixed an issue where some doors at the entrance of main missions would not open after restarting the mission.
    • Fixed a bug where one of the Base of Operation wings would not unlock after completing Subway Morgue or Lincoln Tunnel missions.
    • Fixed a bug where players would not be able to upgrade their Base of Operation wings correctly.
    • Fixed a bug where the Small RDS Scope Mod would not roll weapon damage bonus, even though it was stated in the blueprint as a guaranteed stat.
    • Fixed a bug where the Base of Operations NPC speech was too repetitive.
    • Fixed an issue where the Base of Operations wing resources would not be displayed correctly if at least one of the wings was not activated (laptop not accessed).
    • Players will no longer be teleported to an incorrect checkpoint during the “Rescue: Tenderloin Civilians” side mission.
    • Fixed a bug where using a consumable would not allow the player to aim until the animation finished.
    • Fixed some visual replication problems when swapping weapons while in the Dark Zone checkpoints.
    • Player characters will now properly holster their weapons when climbing over high cover.
    • Improved UI tooltips for trading between players.
    • Fixed an instance where players would be teleported back to the Safe House during the “Hostage Rescue: Midtown East” medical encounter.
    • Fixed a bug where players would be teleported to last checkpoint in Hudson Refugee Camp.
    • Fixed an issue where players could not matchmake for Free Roam from the mega map, while in Brooklyn.
    • Fixed a bug where the Ballistic Shield visual would become corrupted if the player changed shoulder view while using it.
    • Fixed a bug where the defense turrets in Falcon Lost would be able to shoot players through covers from a medium-long range.
    • Fixed some objects in Falcon Lost that would not provide tactical cover.
    • Fixed a number of tooltips not displaying correctly in Arabic localization.
    • Fixed some instances where dead civilians would need things from the player.
    • Fixed a rare case where Rogue status would expire too soon.
    • Fixed a bug where the player could fall through the map in Brooklyn.
    • Crafting will now properly update blueprint stats if the player has switched their Firearms values while in the Base of Operations.
    • Players can no longer phase transfer to a group member’s higher Dark Zone bracket while having Rogue status.
    • Fixed a bug where automatching would return the wrong difficulty for missions when failing to find a match.
    • Fixed a bug where the player’s own character could obstruct aiming while in cover.
    • And many more!
    PC SPECIFIC
    • Fixed a bug where auto-aim would be automatically triggered on PC.
    • Min and Max mouse sensitivity values are now exposed in state.cfg file.
    • Added an option in the game UI that disables all Gamepad input.
    • Added the option to sort inventory items by Gear Score (PC only).
    • Added the option to toggle aim mode instead of holding to aim.
    • Players can now right-click on gear in the Overview screen to get straight to the mod screen.
    • Players can now rebind the ALT key.
    • Players can now exit the game from the title screen.
    • Fixed a bug where the game UI would not center correctly when dual screen is enabled.
    • Fixed scrolling in Mission Overview in the mega map.
    • Fixed an issue where scrolling through possible recalibrations was not always possible using the mouse.
    • Fixed an issue where the wrong recalibration option could be selected at the Recalibration Station.
    • Fixed a bug where some users could loot items from a distance using the mouse cursor.
    • Snap to Marker feature is now smoother while using a keyboard.
    Source: http://tomclancy-thedivision.ubi.com
    Experience: 20,161,718
  2. The Following 5 Users Said Fucking Hell Yeah ! to BIG COUNTRY For This Fucking Post:
    BlameItOnGod13 (May 25th, 2016),CAG JB (May 24th, 2016),CAG SACRILEGE (May 24th, 2016),Destroyer ned (May 24th, 2016),Riddled (May 24th, 2016)
    KingOnyx's Avatar
    Rep Points: 235
    10:40 PM
    Indiana
    Can't wait to get home.
    Sent from my SM-N910P using Tapatalk
    CAG Dogg Level: 22 [?]
    Experience: 45,648
    Next Level: 49,025
  4. The Following User Says Fucking Hell Yeah ! to KingOnyx For This Fucking Post:
    BIG COUNTRY (May 24th, 2016)
    Chet Norris's Avatar
    Rep Points: 14499
    10:40 PM
    Southern Indiana
    Think I'm going to go home for lunch and get it started lol
    Just Win Baby!
    Experience: 861,436
  6. The Following User Says Fucking Hell Yeah ! to Chet Norris For This Fucking Post:
    Rep Points: 119776
    11:40 PM
    All the streamers are saying the incursion feels like a challenge mission . But I am liking what I'm seeing with the HVT's and such
    April 2nd, 2025
    04:40 AM
    Was on there for a quick half hr,enough time to run a few HVT missions.The weapon drop I got from them was an M60 lmg at 163 score(deconstructed)
    Started the incursion with a few randoms and my game froze on me so figured this was a sign that I was to hold on this for fellow CAG Doggs.
    Experience: 52,480,007
    Destroyer ned's Avatar
    Rep Points: 6090
    April 2nd, 2025
    05:40 AM
    the netherlands
    Your on tonight in?
    Verstuurd vanaf mijn SM-G388F met Tapatalk
    Experience: 1,091,820
Members who have read this thread : 5
