Results 1 to 9 of 9
Thread: Your "Must Have" Attachments
Discuss all topics concerning the Black Ops series here
    SixShot's Avatar
    Rep Points: 12307
    02:21 PM
    Montgomery, AL
    So what are your "must have" attachments? You can list out per class, gun or whatever. I tend to always run "Quickdraw" on everything. Also "Grip" comes in handy on most of the faster shooters. The "BOA" sight is almost a must have in HC. Its saved my butt from enemies that like to lay on the ground or that are well camouflaged. I like "Long Barrel" for the ICR to give it a little more range.
    So what's on your gun?
    Experience: 1,303,872
    08:21 PM
    Red Dot
    Quickdraw
    either Grip or Fast Hands depending on the gun.
    I'm off today tomorrow & friday so I'll be playing heavily.
    Experience: 36,061,726
    Ghost's Avatar
    Rep Points: 17320
    12:21 PM
    Ontario , CA
    I do QuickDraw, grip and FMJ with either the Elo or boa3 depending on if I'm holding down or running
    Experience: 3,901,167
    xPARCHx's Avatar
    Rep Points: 79825
    03:21 PM
    Chattanooga, TN
    Always fast hands, quick-draw, grip. Stock on some smgs and lmgs just to give the movement advantage.
    Smgs,shotguns never use sights but on razorback use the elo.
    Elo on almost everything else lmgs and ars.
    Long barrel is good on some ars but some are better with high caliber.
    Manowar with grip, quickdraw, rapidfire and elo is good choice.
    M8A1 with extended mags, high caliber/long barrel and stock
    Hvk with quickdraw/long barrel, rapid fire, elo and grip
    Your perks always help try afterburners, I started using and almost always have to have it now.
    Dead Silence and blast suppressor for stealth with specialist active camo and a shotgun(love doing this)
    Experience: 10,232,505
  5. The Following User Says Fucking Hell Yeah ! to xPARCHx For This Fucking Post:
    PATRON (April 21st, 2016)
    Akedes's Avatar
    Rep Points: 9762
    04:21 PM
    Louisville, Kentucky
    I like quickdraw and stock on ARs and LMGs but quickdraw and grip on my SMGs
    Experience: 2,143,361
    SonOfBuckHunter's Avatar
    Rep Points: 360
    04:21 PM
    Lorain,Ohio
    I use fmj for my weapons and long barrel with a red dot
    CAG Dogg Level: 23 [?]
    Experience: 49,061
    Next Level: 62,494
  8. #7
    CAG_Davies's Avatar
    Rep Points: 11475
    02:21 PM
    Colorado, USA
    Quick Draw Grip and Red Dot for running. Thermal Extended Mag and Grip for holding down.
    Experience: 1,776,402
    iiTz_XenRail's Avatar
    Rep Points: 2350
    12:21 PM
    United Kingdom
    Bravo Co 1st Platoon
    I normally run iron sights on most weapons... QuickDraw , fast mags and rapid fire.
    Best weapon for this combo is the KN-44.
    My perks are a mixture I use blind eye and cold blooded a lot. So score streaks can't kill me.
    Experience: 480,510
    Lambjimb0's Avatar
    Rep Points: 24908
    01:21 PM
    Seaside, OR
    I've been favoring QD, Grip, and iron sights. Till this past month or so, I finally gave in and began using boat, or regular. Every so often I switch it up with stock, long barrel, and fmj.
    Experience: 2,674,626
