Thread: COD: Ghosts Killstreaks And Strikes
Discuss and read about all the Killstreaks and Strikes in COD Ghosts here !
    03:44 AM
    Ghosts - Killstreaks | Strike Packages
    Killstreaks are powerful rewards earned for racking up consecutive kills. Killstreak rewards have many battlefield applications. Some are offensive, some are defensive, and some can be used in tandem with teammates' killstreak for greater effectiveness.
    Ghosts uses the same Strike Chain system that's in Modern Warfare 3. You get to choose one Strike Package: Assault, Support or Specialist and each has its own pros and cons.
    The Assault Package is for aggressive players that rewards with killstreaks that hurt the enemy - the downside is that the streak count resets upon death. On the other hand, the Support Package rewards your teammates with support killstreaks and your streak count persists through death. The Specialist Package gives you perks as your streak progresses.
    Assault Strike Package
    Sat Com (3 kills)
    killstreak
    Replaces the UAV as a stationary ground-based version. Sat Coms can be stacked; the more Sat Coms your team has on the ground, the better they work:
    • 1) Shows enemies on the radar that you and your teammates see / encounter.
    • 2) Sat Coms act as a normal UAV by sweeping the map every few seconds.
    • 3) Increases the frequency of the radar sweeps.
    • 4) Works like the Advanced UAV from MW3 by showing the enemies as arrows, which indicates the way they are facing.
    The Wiretap perk allows you to stack enemy Sat Coms as your own.
    sat com screenshot 1
    I.M.S (5 kills)
    killstreak
    The Intelligent Munitions System shoots anti-personnel grenades in the air when an enemy gets near it.
    Guard Dog (5 kills)
    killstreak
    The Guard Dog will automatically follow you and attack enemies - it also growls when enemy players are near.
    Sentry Gun (7 kills)
    killstreak
    Once deployed the Sentry Gun scans for enemies and attacks them on sight.
    Trinity Rocket (7 kills)
    killstreak
    A remote-controlled missile similar to the Predator Missile from MW3. You can also fire smart drone projectiles while controlling the Trinity Rocket to the ground.
    Battle Hind (9 kills)
    killstreak
    Calls in a Battle Hind that circles the map and automatically engages enemies.
    Vulture (9 kills)
    killstreak
    Deploys a low flying drone that attacks enemies and protects your six.
    vulture screenshot
    Gryphon (10 kills)
    killstreak
    Player controllable quadrotor killstreak that marks targets for detonation. The Gryphon is able to see enemies through walls that don't have the Blind Eye perk equipped.
    gryphon killstreak screenshot
    Maniac (10 kills)
    killstreak
    A Care Package is airdropped into the map that holds the killstreak. Once picked up, you get the Juggernaut armor and a throwing knife - nothing more. Unlike the normal Juggernaut killstreak, this version allows you to move extremely fast, but your health doesn't regenerate.
    Juggernaut (11 kills)
    killstreak
    Works just like the Juggernaut killstreak from Modern Warfare 3. The airdropped Care Package contains the Juggernaut armor and a powerful minigun.
    Helo Pilot (12 kills)
    killstreak
    Allows you to control an AAS-72X Attack Helicopter for a short period of time. The AAS-72X comes with a minigun and flares.
    helo pilot killstreak
    Loki (15 kills)
    killstreak
    Allows you to access the Loki Satellite and use it to assault the battlefield. You can support your team by launching the following armaments:
    • Care Package
    • AI controlled Juggernaut
    • Small Rod
    • Large Rod
    loki killstreak
    Support Strike Package
    Sat Com (4 kills)
    killstreak
    Ammo Crate (6 kills)
    killstreak
    Deploys an Ammo Crate that can be used to supply weapons and ammo to your teammates.
    Ballistic Vests (8 kills)
    killstreak
    Allows you to supply teammates with Ballistic Vests that increases their armor and damage resistance.
    ballistic vests screenshot
    MAAWS (9 kills)
    killstreak
    Fires a rocket that splits into two - you can free-guide the missiles with the launchers laser.
    maaws screenshot
    Night Owl (10 kills)
    killstreak
    A drone that follows you around. It acts as a motion sensor that detects nearby enemies and also deflects missiles that are fired in your direction.
    Even if you die, the Night Owl continues to help teammates.
    Support Squadmate (11 kills)
    killstreak
    Spawns an AI controlled teammate that has a Riot Shield and a handgun.
    support squadmate killstreak
    Ground Jammer (12 kills)
    killstreak
    Disables enemy Sat Coms and killstreaks.
    Air Superiority (12 kills)
    killstreak
    Calls in a fighter jet that engages enemy aircraft.
    Heli Sniper (13 kills)
    killstreak
    Calls in a helicopter with a sniper on-board. The sniper is controllable and the helicopter can be ordered to move around the map. The sniper can be taken out, which ends the killstreak.
    Oracle (14 kills)
    killstreak
    Uses GPS technology to mark enemies and highlight them through walls. The Blind Eye perk makes players immune to the Oracle.
    oracle screenshot
    Juggernaut Recon (14 kills)
    killstreak
    Drops in a Juggernaut armor that has a personal radar that pings nearby enemies. The suit also comes with a Riot Shield and a .44 Magnum.
    Odin (16 kills)
    killstreak
    Allows you to remote control the Odin Satellite to support your team by launching the following armaments:
    • Care Package
    • Smoke
    • Flash/Mark
    odin killstreak
    Specialist Strike Package
    killstreak
    Works almost like in Modern Warfare 3 by allowing you to stack perks as your streak increases. The streak and perk rewards reset upon death.
    You get to choose 3 perks and they are activated in the order you choose them. To be activated, each selected perk requires the same amount of kills the perk costs + one. For example, Marathon costs 2 points, which means you'll need 3 kills to activate it.
    You also get to choose an additional 8 points worth of perks and they are called the "Specialist Bonus". The bonus is activated 2 kills after the 3rd perk (from above) has been activated, meaning you'll need between 8-17 kills, depending on your perk selection.
    Source: http://www.codghosts.net/
    Experience: 290,354,022
    CAG Covieleader (January 13th, 2014)
    LONEWOLF's Avatar
    Rep Points: 46573
    06:44 AM
    Orange Park, Florida
    Great find again Cheech.
    Experience: 12,080,017
  4. The Following User Says Fucking Hell Yeah ! to LONEWOLF For This Fucking Post:
    CAG CheechDogg (November 8th, 2013)
    layserman2's Avatar
    Rep Points: 28063
    10:44 PM
    Australia
    Cheech, you have really done well for those who need some help at Cod Ghosts!
    congratz!
    Experience: 5,528,259
