Thread: Ghost Killstreaks
Any information regarding the 1st Platoon is here. All teams for our GB squads will be present here. All game modes will be represented within BOP2 MLG.
    NIGHTMARE's Avatar
    Rep Points: 14083
    08:32 AM
    Stony Brook, NY
    Ghost Killstreaks
    Ghosts - Killstreaks | Strike Packages
    Killstreaks are powerful rewards earned for racking up consecutive kills. Killstreak rewards have many battlefield applications. Some are offensive, some are defensive, and some can be used in tandem with teammates' killstreak for greater effectiveness.
    Ghosts uses the same Strike Chain system that's in Modern Warfare 3. You get to choose one Strike Package: Assault, Support or Specialist and each has its own pros and cons.
    The Assault Package is for aggressive players that rewards with killstreaks that hurt the enemy - the downside is that the streak count resets upon death. On the other hand, the Support Package rewards your teammates with support killstreaks and your streak count persists through death. The Specialist Package gives you perks as your streak progresses.
    Assault Strike Package
    Sat Com (3 kills)
    sat com killstreak 1Replaces the UAV as a stationary ground-based version. The Sat Coms can be stacked; The more Sat Coms your team has on the ground, the better they work:
    • 1) Shows enemies on the radar that you and your teammates see / encounter.
    • 2) Sat Coms act as a normal UAV by sweeping the map every few seconds.
    • 3) Increases the frequency of the radar sweeps.
    • 4) Works like the Advanced UAV from MW3 by showing the enemies as arrows, which indicates the way they are facing.
    The Wiretap perk allows you to stack enemy Sat Coms as your own.
    sat com screenshot 1
    I.M.S (4 kills)
    ims killstreak 1The Intelligent Munitions System shoots anti-personnel grenades in the air when an enemy gets near it.
    Guard Dog (5 kills)
    guard dog killstreak 1The Guard Dog will automatically follow you and attack enemies - it also growls when enemy players are near.
    Sentry Gun (7 kills)
    sentry gun killstreak 1Once deployed the Sentry Gun scans for enemies and attacks them on sight.
    Trinity Rocket (7 kills)
    assault strike package 7 1Unknown
    Gryphon (8 kills)
    gryphon killstreak 1Player controllable killstreak. Fires explosives and is able to see enemies through walls.
    gryphon killstreak screenshot
    Vulture (9 kills)
    vulture killstreak 1Deploys a low flying drone that attacks enemies.
    vulture screenshot
    Battle Hind (9 kills)
    battle hind killstreak 1Calls in an Battle Hind that circles the map and automatically engages enemies.
    Juggernaut Maniac (9 kills)
    juggernaut maniac killstreak 1A package is airdropped into the map that holds the killstreak. Once picked up, the player gets the Juggernaut armor and a throwing knife - nothing more. Unlike the normal Juggernaut killstreak, this version allows you to move extremely fast, but your health doesn't regenerate.
    Juggernaut (10 kills)
    juggernaut killstreak 1Works just like the Juggernaut killstreak from Modern Warfare 3. The player that picks up the airdropped package receives the Juggernaut armor that comes with a minigun.
    Helo Pilot (12 kills)
    helo pilot killstreak 1Allows the player to control an Attack Helicopter for a short period of time.
    Unknown (15 kills)
    unknown both support assault strike package 1Allows the player to control an aerial vehicle that can support the team by launching the following armaments:
    • Care Package
    • Juggernaut
    • Small Rod
    • Large Rod
    unknown killstreak screenshot 1
    Support Strike Package
    Sat Com (4 kills)
    Ballistic Vests (6 kills)
    ballistic vests killstreak 2Allows you to supply teammates with Ballistic Vests that increases their armor and damage resistance.
    ballistic vests screenshot
    Box of Guns (8 kills)
    box of guns killstreak 1Not been confirmed how it works, but the name implies that a random weapon is given to the player that picks it up.
    Night Owl (9 kills)
    night owl killstreak 1A drone that follows you around. It acts as a motion sensor that detects nearby enemies and also deflects missiles that are fired in your direction.
    Even if you die, the Night Owl continues to help teammates.
    MAAWS (10 kills)
    maaws killstreak 1Fires a rocket that splits into two and you can free-guide them with the launchers laser.
    maaws screenshot
    Ground Jammer (12 kills)
    ground jammer killstreak 2Disables enemy Sat Coms and killstreaks.
    Air Superiority (12 kills)
    air superiority killstreak 2Calls in a fighter jet that engages enemy aircraft.
    Support Squadmate (13 kills)
    support squadmate killstreak 1"Get behind the guy with a Riot Shield" - other than the description, it's not really known how this will work.
    Heli Sniper (13 kills)
    heli sniper killstreak 1Calls in a helicopter with a sniper on-board. The sniper is controllable and the helicopter can be ordered to move around the map. The sniper can be taken out, which ends the killstreak.
    Oracle (14 kills)
    oracle killstreak 2This killstreak was thought to be a cloaking device, but it has been debunked by Mark Rubin via Twitter.
    "Uses GPS(?) technology to detect and display(?) enemies(?)"
    Unfortunately the video compression has made the description for the Oracle partly unreadable, but at this point the evidence suggests that it might mark enemies and possibly highlights them through walls.
    oracle description
    The Blind Eye perk makes players immune to "Oracle systems".
    oracle blind eye
    Juggernaut Recon (14 kills)
    juggernaut recon killstreak 1Drops in a Juggernaut armor that has a personal radar.
    Unknown (16 kills)
    • Care Package
    • Juggernaut
    • Small Rod
    • Large Rod
    Specialist Strike Package
    Works like in Modern Warfare 3 by allowing you to stack perks as your streak increases.
    Experience: 2,110,009
  2. The Following 2 Users Said Fucking Hell Yeah ! to NIGHTMARE For This Fucking Post:
    Kujeaux (November 3rd, 2013),MiSsFiT (November 3rd, 2013)
    GypsyOutlaw's Avatar
    Rep Points: 222306
    08:32 AM
    North Carolina
    looks good cant wait to try some of em out
    Experience: 21,822,312
  4. The Following User Says Fucking Hell Yeah ! to GypsyOutlaw For This Fucking Post:
    Lethal Blade (November 3rd, 2013)
Members who have read this thread : 1
