Call of Duty WW2 Beta Release Date
Just 4 hours ago it was announced that the Call of Duty WW2 Beta Begins Next Month with Division Skills and Training. For all of you COD junkies all the information about the beta is right below.
I personally am still a bit skeptical about this game ... WAW was a very good game but it was completely filled with hackers and they never did anything about it ... For some reason I feel like this game will also be littered with hackers .... Anyways get to reading below !!
https://res.cloudinary.com/pvplive/i...70726-WWII.jpg
By Gregory IbaƱez
Call of Duty: WWII goes into its Private Beta for PlayStation 4 on August 25, featuring all the planned Divisions for the game, and will re-open to include Xbox One on September 1. The PC version should have a beta at a later date.
In addition to the Call of Duty: WWII beta dates and start times, Activision shared additional details about each Division, highlighting Skills and Training. It's important to note that each of the Division Skills and Training are marked by Activision as Rank III, which means you can level up each multiple times, making them more effective with each successive Rank.
Private Beta (PS4 Only)
- Begins on Friday, August 25 at 10AM PT
- Ends on Monday, August 28 at 10AM PT
Console Beta (PS4 and Xbox One)
- Begins on Friday, September 1 at 10AM PT
- Ends on Monday, September 4 at 10AM PT
Armored Division
The Armored Division is the cornerstone of any team on objective-based game modes. With your LMGs you can suppress the enemy team to provide your team with space and time to flank or recover health.
And this Division is not weak by any means. You'll have armor to protect you from enemy explosives, equipment, and flamethrowers.
Division Skill
- LMG Bipod III: Protect territory by mounting your machinegun on ledges or while prone for less recoil
Division Training
- Armored III: Immune to Shell Shock and Tactical Equipment. Take less fire damage. Take less explosives damage.
Mountain Division
WWII's Mountain Division specializes in stealth and long range gameplay. Using sniper rifles, you can pick off advancing enemies with ease, getting aim assist through your Division Skill, while also remaining undetected by enemy recon with your Division Training.
As a Mountain Division soldier, you'll have access to Bouncing Betties (if you're unfamiliar, they are essentially claymores) and smoke grenades.
Division Skill
- Sniper Sharpshooter III: Block out your surroundings and in return acquire aim assist and enemy names while holding breath.
Division Training
- Mountain III: Invisible to enemy Recon Aircraft while moving. Hidden to player-controlled Streaks. Quieter Movement.
Airborne Division
If you prefer to run-and-gun, the Airborne Division is the right choice. You'll have access to submachine guns, which you can equip with a suppressor on the fly. With your increased movement speed you can flank other players quickly and create opportunities for your teammates.
Division Skill
- SMG Suppressor III: Hides muzzle flash and prevents gunfire from appearing on enemy mini-maps, but reduces range of weapon.
Division Training
- Airborne III: Sprint for longer distances. Climb over obstacles faster. Increased sprint speed.
Expeditionary Division
You may be locked into close-quarters combat as an Expeditionary Division soldier, but you can maintain a constant supply of explosives and tactical equipment by killing enemies.
Division Skill
- Shotgun Incendiary Shells III: Shotgun shells that spark flames that burn enemies.
Division Training
- Expeditionary III: Select a piece of Tactical and Lethal Equipment. Throw equipment faster, farther & while sprinting. Resupply equipment from killed enemies.
Infantry Division
The Infantry Division is the final set-piece for Call of Duty: WWII. You can play at any range, and with any style effectively, but you won't have the specializations like the other Divisions.
Division Skill
- Rifle Bayonet III: Special training on the use of the bayonet makes Infantry riflemen a threat at all ranges.
Division Training
- Infantry III: Additional attachment on Primary Weapon. Extra magazines. Move faster while aiming down sights.
Source: https://pvplive.net/c/call-of-duty-w...-all-divisions
