Do we have maps for Black ops 3 to show the positions we're supposed to hold down?
I can't remember seeing any maps with hold down positions on them. The concept is simple tho. On most maps there are three lanes, left, right, and middle. So if you have a group of six CAG Dogs there would be two positioned left, right, and center.
Once IW drops I believe we or I should possibly look into doing videos of various locations. I could do the other method of having dots pertaining to the positions also on above map. Ya gotta wonder if the IW maps will have 3 lanes but yes normally you do the 2 2 2 setup with folks often rotating depending on how the traffic. Ex. Left Side on Combine we've seen folks get nuclears off that spot.
So sit tight as we get closer to launch. COD 4 would ideally be a Charlie Delta since all the maps are mostly open lane and no boost jumping.
Sounds good. I was more referring to recommend locations that more experienced players have seen that work best. Some maps the best spots aren't as clear for cover and concealment.
Sent from my SM-N920P using Tapatalk
Ah yes well if ur on Xbox shoot me a message I can go over them if u would like.
Keep in mind I always have 2 or 3 spots per side so that ur not always their. U wonna catch the enemy off guard and surprised. Of all my years playing cod a moving camper is hard to hit because ull never know when or where I'll be
Sent from my SM-G930V using Tapatalk
I am usually on 2100 pst so I am not sure if our schedules match up that well
